It is currently Tue May 05, 2026 12:00 am
 Post subject: Fan hitting shroud
PostPosted: Fri May 27, 2011 12:33 am
Fan is hitting fan shroud, but will stop when I pull up on the alternator. Can I shim the alternator? or do I need to do something else? Thanks
 Post subject: Re: Fan hitting shroud
PostPosted: Fri May 27, 2011 2:34 am
You can shim the fan.. I am not sure about the alternator.
PostPosted: Fri May 27, 2011 10:22 am
My brother had the same problem and it was the bolts that hold the alternator to the tin. The bolts are behind the fan.
PostPosted: Fri May 27, 2011 4:18 pm
When mine did that it was the fan itself had broke behind the nut. Had to replace the fan.
PostPosted: Sat May 28, 2011 1:00 am
IF! your fan is straight and true take some RTV and glue the gap and the next day cut it loose with a razor blade and you will have an air tight seal from hell. Remember air comes in and 1 way out. Keep it sealed. Does water cooled have leaks?
PostPosted: Mon May 30, 2011 8:58 pm
Had to trim the the bottom of the shroud. Thanks for the help
