| Fan hitting shroud http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=11788 |
| Author: | MIKEW [ Fri May 27, 2011 12:33 am ] |
| Post subject: | Fan hitting shroud |
Fan is hitting fan shroud, but will stop when I pull up on the alternator. Can I shim the alternator? or do I need to do something else? Thanks |
| Author: | MickeyMouse [ Fri May 27, 2011 2:34 am ] |
| Post subject: | Re: Fan hitting shroud |
You can shim the fan.. I am not sure about the alternator. |
| Author: | Huey [ Fri May 27, 2011 10:22 am ] |
My brother had the same problem and it was the bolts that hold the alternator to the tin. The bolts are behind the fan. |
| Author: | fgrir [ Fri May 27, 2011 4:18 pm ] |
When mine did that it was the fan itself had broke behind the nut. Had to replace the fan. |
| Author: | passat2800 [ Sat May 28, 2011 1:00 am ] |
IF! your fan is straight and true take some RTV and glue the gap and the next day cut it loose with a razor blade and you will have an air tight seal from hell. Remember air comes in and 1 way out. Keep it sealed. Does water cooled have leaks? |
| Author: | MIKEW [ Mon May 30, 2011 8:58 pm ] |
Had to trim the the bottom of the shroud. Thanks for the help |
