PostPosted: Mon May 23, 2011 1:37 pm
I have a problem with starting my buggy,when the motor is cool it starts up just fine,but after i run it for about 20min it will not start the starter hardly turns the motor over,let it set for 15min it starts up just fine,every thing is new,battery,battery cables,starter and bushing,I'm thinking about buying a hightorque starter the motor has 9.7 comp. 2332, with fuelinjection. What do u all think.
PostPosted: Mon May 23, 2011 1:48 pm
Check valve adjustment?
"IT IS WHAT IT IS"
PostPosted: Mon May 23, 2011 1:55 pm
check the timing
PostPosted: Mon May 23, 2011 2:03 pm
The timing is fine. I'll check the valves.
PostPosted: Mon May 23, 2011 5:06 pm
is the bushing good in the bellhousing?
i would just put on a high torque and be done with it
PostPosted: Wed May 25, 2011 2:00 pm
get it figured out?
"IT IS WHAT IT IS"
