| Front Beam Spacing http://woodsbuggy.com/phpBB3/viewtopic.php?f=2&t=1091 |
| Author: | RailHomie [ Wed Sep 05, 2007 4:05 pm ] |
| Post subject: | Front Beam Spacing |
Hey, quick question. What exactly is the difference (measurement) in the tube spacing between the balljoint and king/linkpin beams? I think I'm going to convert the front mounts on my chassis. Thanks, Pat |
| Author: | MadMike [ Wed Sep 05, 2007 6:18 pm ] |
| Post subject: | |
Which way are you going, ball joint to link pin? |
| Author: | RailHomie [ Wed Sep 05, 2007 7:03 pm ] |
| Post subject: | |
Linkpin to Balljoint. I've pretty much decided it's going to see more pavement than dirt and wouldn't be worth the extra cost to get a linkpin frontend. I know you all are going to give me hell, but that's pretty much what I've decided, heh. |
| Author: | Blake [ Wed Sep 05, 2007 7:12 pm ] |
| Post subject: | |
Mine's 100% off road with a ball joint, it rides nicer and I haven't had a problem and I'm rough on it. -Blake |
| Author: | RailHomie [ Thu Sep 06, 2007 8:20 am ] |
| Post subject: | |
Ah, excellent. That's good to hear. It's definitely decided then. So, does anyone know the measurements? If anyone knows the spacing of the balljoint beam, throw it up here. If someone knows the spacing of the kingpin beam, throw it up here. Then I can subtract. Thanks! |
| Author: | Joe [ Thu Sep 06, 2007 10:07 am ] |
| Post subject: | |
Kingpin beam C/L to C/L is 4 3/4" and the Balljoint C/L to C/L is 6" |
| Author: | RailHomie [ Thu Sep 06, 2007 10:13 am ] |
| Post subject: | |
Alright, I'll have to open it up 1 1/4 inches, that shouldn't be a problem. Thanks Joe, you're a good man. Exactly what I needed. |
| Author: | DVS1 [ Thu Sep 06, 2007 10:48 am ] |
| Post subject: | |
So let me get this straight. You are going to convert the frame to accept a balljoint frontend, not the beam it self? |
| Author: | RailHomie [ Thu Sep 06, 2007 10:51 am ] |
| Post subject: | |
Correct. I worded that kind of weird when I said "open it up," my bad. I'm gonna bend the top tubes up a bit, maybe cut them back some too, depending on the angle it gives me. |
| Author: | DVS1 [ Thu Sep 06, 2007 11:00 am ] |
| Post subject: | |
Ok, if you are going to be driving on the road, I suggest that you figure out what degree the frame beam mounts are and try to get the fabrication of the new mounts as close to that angle as possible. this way the bj beam castor and camber will be as close to stock as possible. This will help with any steering problems especially at high speeds on the road. Good Luck! |
| Author: | RailHomie [ Thu Sep 06, 2007 11:06 am ] |
| Post subject: | |
Yeah, I will definitely be taking that into consideration and doing a bit of research on that. Thanks a lot man, look forward to meeting you on the trails sometime! I'm going to get some pictures up of my project and updates eventually, but haven't gotten around to it yet. |
| Author: | MadMike [ Thu Sep 06, 2007 11:28 am ] |
| Post subject: | |
Thoes numbers are not correct. The centerline to centerline on a link/king pin beam is 5.211". The c/l to c/l on a ball joint beam is 5.894", giving you a .683" difference which is just under 11/16". Also note that when you "open up" the spread on the upper rails it will cause the torsion housing assembly to lean back ever so slightly, hardly noticable. I would suggest, if you MUST use a ball joint beam, lightly bolt in the BJ beam into the upper clamps heat and raise the upper rails untill the BJ beam just fits into the lower clamps and bolt it all up tight to help hold the set untill everything cools off. |
| Author: | RailHomie [ Thu Sep 06, 2007 11:40 am ] |
| Post subject: | |
Ah, well thanks for the correction, though I do like your idea so it wouldn't matter anyway. I already have the frame welded solid so I wasn't going to raise the front of the armrails, so no problems there. That small of a difference in spacing shouldn't pose any problems at all, that's great. Thanks man. |
| Author: | RailHomie [ Thu Sep 06, 2007 11:42 am ] |
| Post subject: | |
Just to make that clear...I am going to heat and bend the front of the armrails. |
| Author: | Joe [ Thu Sep 06, 2007 2:04 pm ] |
| Post subject: | |
My bad, I took a tape and eye-balled mine and my brothers. Just trying to help out. Still a good guy just a bad tape or eye balls. |
| Author: | RailHomie [ Thu Sep 06, 2007 2:08 pm ] |
| Post subject: | |
HAHA, I haven't a doubt in my mind that your still a good guy. Your measurement was better than anyone else's at the time. |
| Author: | MadMike [ Thu Sep 06, 2007 3:32 pm ] |
| Post subject: | |
[quote='Joe']My bad, I took a tape and eye-balled mine and my brothers. Just trying to help out. Still a good guy just a bad tape or eye balls. Remember, I'm a machinest and it's a curse to be accurite and ya I had to get my glasses out to see too |
| Author: | DVS1 [ Thu Sep 06, 2007 3:35 pm ] |
| Post subject: | |
We believe your are a good guy. But I think your eyeballs are bad considering your avatar has a buggy in it with no earth under it.(lol) |
