PostPosted: Mon Aug 09, 2010 5:15 pm
was curios on degreaser products available to the public ? im trying to get 25 years of grease off and was trying purple power and it just is not cutting it ! lets here what is out there that will be worth a try !
thanks jason
PostPosted: Mon Aug 09, 2010 5:17 pm
I don't know if you can get it out there but we use Bilt Hambers' Surfex HD for everything these days, fantastic stuff, cheap too.
PostPosted: Mon Aug 09, 2010 6:37 pm
Zep formula50 is by far the best I have used. We have a parts washer with zep in it at work. I like it better and use it more than the solvent parts washer. You can put parts in it and let it run across them. They come out without any oil stains on them. I put the transmission case out of my wife 78 Jeep CJ and it took me less than 5 minutes to clean the transmission after letting it run for a while. When I brought it home she asked me where I found her a new transmission case.
PostPosted: Mon Aug 09, 2010 6:45 pm
where you get that zep 50 at and how much does it cost?
i got a new 40 gal. parts washer i need something to put in it but all the solvents are so high i hadnt even put it together yet
PostPosted: Mon Aug 09, 2010 6:57 pm
i jus bought one to and i put offroad diesel in it and it works real good,it probaly wont hold 20 galsi think mine is 30 gal and it held 16 or 17 gal
PostPosted: Mon Aug 09, 2010 7:01 pm
if u can get it the green stuff at the car wash when u put it on wheel cleaner,,,i got a couple gallons of it and it does the job,put it on the whole car,i do mine everytime i ride
PostPosted: Mon Aug 09, 2010 7:21 pm
Out of curiousity what are you degreasing? Your driveway,something on your buggy or just curious in general?
PostPosted: Mon Aug 09, 2010 10:25 pm
cleaning a six rib , i tryed spraying purple power and pressure washing it but still is a little greasy . im going to paint the tranny so i would like it as clean as possible !
jason
PostPosted: Mon Aug 09, 2010 10:32 pm
clean the heavy stuff off and then use oven cleaner let it set for about 20 30 mins and hose off that how we clean motor blocks works very well my have to do it 1 or 2 times
PostPosted: Tue Aug 10, 2010 2:47 am
Its more than likely has the under coating on it,your gonna need kero or #2 to loosen it
PostPosted: Tue Aug 10, 2010 7:25 am
:roll: i betcha your correct , did not even think of that !
PostPosted: Tue Aug 10, 2010 12:33 pm
Autozone delivers a 20 gal drum of Zep to work so I'd assume you can get it from them in smaller amounts.
PostPosted: Tue Aug 10, 2010 12:52 pm
Screw all that cleaning, just get it sandblasted.
Drill and tap the vent hole for a 1/8" pipe plug, you can seal up the shift rail and input shaft with rags and duct tape. For a nice job you'll just have to do a little hand cleaning around the input, shift rail and pull the flanges to clean up behind them.
With some new nylock nuts and a little attention to detail you can make it look like a brand new one.
