It is currently Tue May 05, 2026 6:31 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jun 23, 2010 12:47 pm
Duramax does not have a lift pump. The fuel supply/high pressure pump on the motor is all it has.
PostPosted: Wed Jun 23, 2010 2:12 pm
Willie, which duramax do you have? The LLy or the LBZ?
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Wed Jun 23, 2010 10:40 pm
you may be right ( im no bowtie fan ) but there sure are a lot of adds show up when you do a search for "06 duramax lift pump" but they could only be necesary for modded engines :?
PostPosted: Thu Jun 24, 2010 10:30 am
I was under the impression the duramax uses a cp3 pump?
PostPosted: Thu Jun 24, 2010 10:50 am
they have around 20000 psi from the pump to injectors
PostPosted: Thu Jun 24, 2010 12:01 pm
It does use a cp3 pump, you're correct. They use a common rail fueling system.
-Dakotah/koko
-Dakotah/koko
PostPosted: Thu Jun 24, 2010 12:28 pm
does that have any bearing on whether or not they have a lift pump?
i thought the cp3 was just an injection pump :?
PostPosted: Thu Jun 24, 2010 12:48 pm
The CP3 is an injection pump. Usually diesels have lift pumps. The LBZ Duramaxes DO use lift pumps, the LLY, LB7, and LG4 do not. The common rail cummins, and the vp44 pumped Cummins use lift pumps. The 12v Cummins (HOO RAH) uses a block-mounted lift pump. On the Duramaxes that don't have a seperate lift pump, there's a high pressure side and a low pressure side of the CP3 pump. The low pressure side pulls the fuel from the tank to the motor, and the high pressure side delivers the fuel to the fuel rails. Duramaxes WITH a lift pump still have a low-pressure side of the CP3 pulling fuel, but the lift pump helps shove the fuel to the pump. The only reason the CP3ed Common Rail Cummins started using seperate lift pumps was to make it easier to prime the fuel system after a fuel filter change, etc. Same for the Duramaxes. They can both run with a failed lift pump, or without one, they just won't get as much fuel, resulting in a power loss. That's why the LBZ Duramax is rated with more HP/TQ than the other Duramax engines, because it uses a lift pump, allowing them to turn the fueling up from the factory.
-Dakotah/koko
-Dakotah/koko
PostPosted: Thu Jun 24, 2010 8:51 pm
Set 'em straight, Koko. :wink:
PostPosted: Fri Jun 25, 2010 1:25 pm
-Dakotah/koko
thanks for the info koko, i was confused because i have an 06 cummins and was 99% sure it had the cp3 injection pump on it but i was also 100% sure it had a lift pump 8)
PostPosted: Sun Jun 27, 2010 3:33 pm
Glad I could help. :D You're right though, yours is a common rail Cummins with the CP3 pump and a lift pump.
-Dakotah/koko
-Dakotah/koko
Users browsing this forum: No registered users and 4 guests
