Go Big Or Go Home wrote:
Lots of good info here. Big thing to look at is how much emissions crap is on the truck. The 6.0 Fords aren't all that bad if you do a EGR delete. I had one as a route truck and it had a complete overhaul at 108,000 and they told me it could happen again at anytime unless I did away with the EGR and I wasn't willing to take that chance on a commercial vehicle so I traded it in for a new 6.7 (F-550)and it is awesome! Lots of power and torque. It has about 40,000 on it now with no problems. Personally I have a 08 Ford with a 6.4 twin turbo. If you leave it stock it sucks. But I have dumped a couple grand into it and wow what a difference. I have a DPF delete, EGR Delete, aftermarket intake and a Spartan tuner. It runs like a top with no problems since. I get 20+ on the highway and about 15 towing. One of the diesel mags did a review on the tranny in these things and they were amazed at the abuse they take. I am as well... I run my truck on a +275hp tune when not towing and it shits and gets and the tranny takes it. I have a little over 100,000 now and the only problem I had was the EGR went bad which prompted me to delete it. They put a new one on under warranty and it only had about 4000 miles on it when I removed it to put the delete kit on and it was completely gunked up already. The only other bad thing about them... and I think you will find this with about any of these newer diesels... they eat tires like crazy for some reason!
I haven't had any tire issues. I just replaced with the original BF Goodrich and the first set had 65,000 miles and the second is at 41,000 now. They will need replaced about the same time. For heavy hauling and towing I can't complain. I also plow snow with these tires and they get spun a lot whether stopping or starting when it's slick. I do try and keep them rotated though since 6 truck tires are expensive.
