It is currently Mon May 04, 2026 7:03 pm
 Post subject: help ?
PostPosted: Mon Oct 18, 2010 11:09 am
we were riding 2 weeks ago , and i hit a hill and it acted like i blew a cv. Came down the hill backwards , but when i got to the bottom the buggy moved. Ran it like that the rest of the day, but now its bunny hopping when i let out on the clutch . it got real bad saturday when we were out .
1) cv's and axles are ok
2) motor and tranny were bolted tight
3) pulled my 5 rib apart - spider gears and all the other gears look good
I'm lost -- anybody have any ideas?
harleys and vws----ac all the way
I love my country, But i fear my government
Last edited by harleyhunter05 on Fri Oct 22, 2010 1:59 pm, edited 1 time in total.
 Post subject: Re: cv joint?
PostPosted: Mon Oct 18, 2010 11:28 am
harleyhunter05 wrote:
we were riding 2 weeks ago , and i hit a hill and it acted like i blew a cv. Came down the hill backwards , but when i got to the bottom the buggy moved. Ran it like that the rest of the day, but now its bunny hopping when i let out on the clutch . it got real bad saturday when we were out - could it be a crack in a cage causing it?
Might be a broke engine or tranny mount,,,that will even tug on the throttle sometimes too.
PostPosted: Mon Oct 18, 2010 11:32 am
I'll check it over - I dont usually half break stuff, Its usually real easy to figure out whats broke :oops:
 Post subject: Re: help ?
PostPosted: Fri Oct 22, 2010 4:09 pm
i edited the post above and changed the topic name - any ideas?
PostPosted: Fri Oct 22, 2010 4:17 pm
most of the time if its hopping like that its the front trans mount loose or broke frame horns.i run my axles without clips and i have had an axle come out of the cv on a bad rutted hill i was setting sideways and knew i had spun it.got the buggy pushed around when i got to the bottom it had went right back in.it's happened to me a few times.but that should not have caused it to start hopping.you have something loose or broken in a main support somewhere.chad :mrgreen:
