It is currently Tue May 05, 2026 1:37 am
PostPosted: Sun Aug 01, 2010 9:24 pm
If you made it to golden mountain, I am looking for some feedback of the numbering system. Where the numbers easy enough to read? Easy to swap in and out? Do you think there should be one more number on the back of the buggy or is two enough?
Let me know your thoughts and ideas...
Thanks
PostPosted: Sun Aug 01, 2010 9:32 pm
2 is plenty we need to figure out a way to keep them in the plastic i seen them on the right way and the wrong way and they still fell out maybe a little bit of tape. :idea: :D And just incase ive never told you you are a big help to this series thanks alot. :D 8)
PostPosted: Mon Aug 02, 2010 6:06 am
I AGREE WITH PIPEDOPE COMPLETELY, YOU DO A GREAT JOB KEEPING EVERYTHING MOVING AND IN ORDER.I THINK ITS THOSE TWO LITTLE HELPERS YOU HAVE! :D :D :D
PostPosted: Mon Aug 02, 2010 9:15 pm
WB Competitor
i agree with both of them... it aint the same when your not there.
PostPosted: Mon Aug 02, 2010 10:03 pm
Thanks for the kudos. But it really is a team effort. I just like to talk a bunch on the mic.. :lol:
As for the numbers, I will stick with two (one on each side) and see if I can find a way to have the numbers stay in the sleeve a little better.
PostPosted: Tue Aug 10, 2010 8:23 pm
turn them 90 degree's and replace #. slide in from top. all drivers hold on to the bag. turn # in . been thinking about this. wife does not understand. what about it. :D :D :D :lol: :lol: :lol: :?: :?:
George & "G"girl --George went and got his own login so it just me... Sandra
A day spent with friends is always a day well spent!
Just because your mouth has the ability to open, doesn't mean you should let it.
PostPosted: Tue Aug 10, 2010 10:06 pm
how bout a staple gun & staple the middle of the open end & remove the staple with a staple puller & you can keep them to reuse several times that way (possibly all season) since the staples are so small !! :wink: :wink: :wink: :wink:
PostPosted: Wed Aug 11, 2010 12:45 am
I have been running some tests and I think I have figured out how to keep the numbers to stay in. We will see at windrock..
