It is currently Tue May 05, 2026 6:32 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Mon Apr 12, 2010 7:34 pm
I am willing to help. If you could take it to Tim and let Willie help you out that would be your best bet. We will get you going again . I really hate that it happend.
DAREK
I want to die in my sleep like my grandpa. not screaming like the passengers in his car...
PostPosted: Tue Apr 13, 2010 1:29 am
i dont think you will go wrong listening to bobby or letting him work on your engine or tranny for that matter if you ever need it and he is a good guy also imo.
sorry to hear this happened especially to somebody new to buggies as this is what causes some to dislike them but when one is built right and properly maintained they are very dependable and loads of fun also
maybe when you get it going again i can get a few together to come up and ride with yall at bruton, we almost came this past sunday but ended up at wilborns instead
PostPosted: Tue Apr 13, 2010 11:21 am
These things happen. Buying a built performance buggy for a first time rider can be really tough especially when you don't know much about them. Starting with a beater and a stock engine has big advantages. People see us running hard and fast and don't realize we spent time in the school of hard knocks to get there. The three rib attached to my 2180 is many years old and still works. Same with the 20 year old 2180. I learned just how hard to run from watching what the others did to kill parts on their buggies and from advice from seasoned riders. That way I knew how much abuse parts will take. There is a difference betwen hard and abusive. Oil leaks in VWs are normal. I have had breather hoses fall off, the oil does not come out fast, a sucked in valve cover gasket will. My valve covers are modified to not let that happen. I have a oil temp and oil pressure guages but most often my nose catches the leak first. Any time I get out of the rail I walk around it and inspect. I also have a quiet exhaust so I can hear the rail talk to me. At least this lesson did not cause you any bodily damage.
PostPosted: Mon May 24, 2010 3:46 pm
bobby ended up buying this buggy,3 rods where bent,stock rods,2 cylinders where rusty on the bottom side,transmission was junk,wont go into 3rd or 4th,pinoin bearing was spinning in case,we like to never got pinoin nut off,but he did get a really nice frame,jus no motor or tranny
PostPosted: Mon May 24, 2010 7:59 pm
OUCH :shock:
lets just ride
PostPosted: Mon May 24, 2010 8:04 pm
bmoore wrote:
OUCH :shock:
he got it cheap enough,so all that was ok,,he knew the motor was junk
PostPosted: Mon May 24, 2010 8:46 pm
that same thing happened to me when i built my first buggy it ran 15 minuets and then it locked up
i kinda know what it feels like
just get it running again and ride it, it will be worth it :mrgreen: :mrgreen:
PostPosted: Tue Jun 15, 2010 9:32 pm
That happend to me on my first buggy bought in florida with all good hopes got it to ohio had a hard time getting it running right then when i did i pulled it out of my garage got about 5 feet and it locked up tighter then shit so next day i went to la products bought a new motor stuck it in pulled it out of garage and same thing happend so i was like what the "F' is going on so i took the buggy and motor up to la and guys there looked at everything and here my through out bearing was the wrong one for my clutch and was putting to much pressure on my bearings and caused them to spun. so i learned to double check every thing i buy now
PostPosted: Tue Jun 15, 2010 10:51 pm
never heard of that
PostPosted: Thu Jun 17, 2010 12:40 am
neither did i but it happend to me i was in total shock when they told me so i replaced the through out like they said waited a week for my new motor to be rebuilt stuck it in and boy was i scared it took me bout 10 mins to let the clutch out cuz i was affraid that wasnt it but sure enough everything worked
