It is currently Tue May 05, 2026 4:06 am
 Post subject: Power Rack Modification
PostPosted: Sun Dec 27, 2009 7:42 pm
For those that were interested, here is the write up on modifying the Corsica or Beretta power rack for use in a bug or sandrail. The mod allows you to put the rack against the back of the beam so installation is much simpler.
Mark
http://blindchickenracing.com/How_to/po ... errack.htm
Mark "Crash" Johnson
Blind Chicken Racing
http://www.blindchickenracing.com
PostPosted: Sun Dec 27, 2009 8:12 pm
That mod will make that rack an ideal steering setup,,thanks for posting. :wink:
PostPosted: Sun Dec 27, 2009 8:53 pm
Sweet Ive been waiting for these pics. Cant wait now to rip mine apart.
PostPosted: Thu Jan 14, 2010 5:13 pm
Seems like that is alot of work when you can bolt it on with out al that work. One just has to be a bit conscientious when lining things up.
Off-roading is NOT a spectator sport
If you can't buy it....Make it
You know, water and electricity dont mix (from a nurse at a hospital)
Two turtles don't make a rabbit
PostPosted: Thu Jan 14, 2010 6:24 pm
I ran that rack for a while with all the changes I could think of in alignment and never got the bump steer out. So I went to a econo rack that enabled me to get the geometry right. But I would still be using that rack if I could get the tie rods at the rack forward up near the beams to eliminate the bump steer without the tie rods hitting the rack ends. On a VW trailing arm front end the tie rods need to meet up near the beams or you will have bump steer.
