It is currently Tue May 05, 2026 6:26 am
PostPosted: Wed Aug 26, 2009 12:44 pm
This may have been posted elsewhere already but worth of repeating.
http://www.brewracingframes.com/id75.htm
Scary stuff.
Thanks
PostPosted: Wed Aug 26, 2009 1:14 pm
GEEZ!! Thanks for passing that along.
PostPosted: Wed Aug 26, 2009 5:42 pm
I used to have a Brew BMX Frame... He welds frames for quite a few BMX Companies... That is scary..
PostPosted: Wed Aug 26, 2009 8:42 pm
Nasty stuff, no more brake clean as weld prep for me.
PostPosted: Wed Aug 26, 2009 8:48 pm
thats scary i use brake cleaner to prep metal all the time. well up until i read that. thanks for posting!
lets just ride
PostPosted: Wed Aug 26, 2009 9:19 pm
Thanks for the post. I just ran out of carb cleaner and was going to use brake cleaner to remove the cutting oil before welding my x brace in.
PostPosted: Thu Aug 27, 2009 5:31 pm
:twisted: i use carb/brake cleaners to but i also use the compreser to blow dry before i start. mabey thats whats saved me from this.
PostPosted: Sat Aug 29, 2009 5:32 am
http://www.osha.gov/doc/outreachtraining/htmlfiles/weldhlth.html
a.k.a."PittsburghJim" on www.dune-buggy.com
PostPosted: Tue Sep 01, 2009 4:07 pm
WoW! I use brake cleaner and Laquer thinner to clean joints before welding. I let them dry before I weld however only because they are flamable. I did not consider the toxic aspect. I know that Galvanozed steel is pretty toxic to weld so limited exposure for sure.
PostPosted: Thu Sep 03, 2009 8:04 pm
In my trade (HVAC) R-22 freon also causes phosgene gas when it comes in contact with fire. I had a similar experience soldering a unit in, but not as bad....
PostPosted: Fri Sep 04, 2009 11:50 am
I've heard of that too.
Old school mechanic told me they used to check for freon leaks with a propane torch and some sort of tube.
Get the tube around a freon leak and it would siphon the freon into the flame
A leak turns the flame green.
PostPosted: Sat Sep 05, 2009 10:17 am
Yep ,thats the old school way to check for leaks. Although its not in production anymore, R-22 has hydrogen and chlorine in it and will turn into a nerve gas (phosgene) when comes in contact with flame....you know people used to sniff freon to get high.
PostPosted: Tue Sep 15, 2009 8:26 am
Used to? They still do.
About 2-3 puffs of R22 will knock your socks off if not kill ya.
PostPosted: Wed Sep 16, 2009 9:46 pm
very usefull info. hope that everyone reads this post. very scary deal.
!DRIVE IT LIKE YOU STOLE IT!
PostPosted: Sun Oct 04, 2009 3:44 am
Very lucky indeed. I did find some information about some brake cleaners that have Tetrachloroethylene in them. It seems that Tetrachloroethylene are in all the NON-flammeable brake cleaners. With that said, NIOSH recommends that tetrachloroethylene be regulated as a potential human carcinogen.
Below is the first responder information on tetrachloroethylene:
http://webwiser.nlm.nih.gov/getSubstanceData.do?substanceID=207&displaySubstanceName=Perchloroethylene&UNNAID=&STCCID=&selectedDataMenuItemID=1
cron
