It is currently Tue May 05, 2026 6:26 am
PostPosted: Mon Sep 28, 2009 11:53 am
I got a buggy sunday on a trade here is the specs
single dellorto
3 rib with problems and an extra 3 rib
1915
goodyear terre tires 31's
tractor 3 rib fronts
96 inch wheel base
ext oil cooler with a adapter for a spin on filter
oil pres and temp gauges
single cutter handle
bent ball joint front
reinforced rear arms
car irs rear torsion
several welds that might be bubble gum painted over.
engine came from strictly vw in cali build sheet says
8 dowel crank
balanced rods
110 engle cam w bolt on gear
cima pistons
new solid shaft rockers with swivals
12 lb light flywheel
that what the sheet says.
I'm really leaning towards using all the parts on it to build my other frame.
It's a 120 inch wheelbase midengine.
I want to make it a rear engine with a small back seat. Just gonna use the little 2 kid bench.
What is a good wheel base for this. Any ideas?
Also anything in engine specs throwing up a red flag that it has a weak point or something that just sucks
PostPosted: Mon Sep 28, 2009 12:22 pm
Sounds good to me. How bout some pics?
PostPosted: Fri Oct 02, 2009 10:49 am
I'm workin on the pics.
