It is currently Sun May 03, 2026 10:37 pm
 Post subject: Check out my Rod!!!
PostPosted: Tue Jul 10, 2007 2:56 am
Well the new tie rods only lasted 3 trips. I went to Walhonding, OH Saturday and the first 5 minuets of riding I got about 5
PostPosted: Tue Jul 10, 2007 7:42 am
You just had to show off that weld didn't you? :oops: :roll:
PostPosted: Tue Jul 10, 2007 10:37 am
Thats the good side :)
PostPosted: Tue Jul 10, 2007 11:28 am
Drews Off Road has alum.tie rods with International ends already set up for $100-$120.They are 1" or so wider than stock,so all you have to do is cut them down 1/2"on each side with a hack saw.1-888-463-7397.
PostPosted: Tue Jul 10, 2007 12:53 pm
[quote='hillaholic']Thats the good side :)[/quote]
Thanks buddy :lol: Few less beers earlier in the day and it might have looked a little better. All joking aside it did make it the rest of the night and was evidently stronger than the tie rod since most of that bend came after the booger weld job.
PostPosted: Tue Jul 10, 2007 4:43 pm
Brad, this is where I got my tie rod tubes. I have the steel tubes with swedged ends. You can get them in increments of 1". Call them and tell them what measurements you need, center eye of rack to center eye of steering arm and they will get you the right size. I think I paid about $15 to $18 a tube. Check them out www.southwestspeed.com When you coming back down?
PostPosted: Tue Jul 10, 2007 8:20 pm
Man I saw the heading and I thought it was another spammer!!! :lol:
PostPosted: Wed Jul 11, 2007 6:11 pm
brad i tried the aluminum ones bent first time out.race car fab shops sell tubeing and threded weld in ends.I use s and w race cars for stuf like that.tubeing is sold by the foot.
PostPosted: Thu Aug 23, 2007 4:09 am
I finally got my new hex rods and free stabilizer installed. I think the new hex rods will hold up a little better than the round aluminum rods I had. The rods cost $20 for the pair with the 11/16
PostPosted: Thu Aug 23, 2007 6:23 am
Where did you get the hex rods? I need to replace my cheap aluminum rods. I have one that is bent really bad.
Stabilizer job came out good Brad.
Roy
PostPosted: Thu Aug 23, 2007 11:15 am
I got them from LA Products in Akron, OH. They can make them any length. They were going to charge $70 for the entire set up (2 rods, 2 International ends, 2 Ford ends) but they only had 1 of each rod end, so they charged $50 total. $20 for the rods and $15 for each rod end. I researched the price on the taps to do it myself and it would have cost almost $120 just for the taps
PostPosted: Thu Aug 23, 2007 7:43 pm
I can't belive your STILL messing around with tie rod ends. Get a set of 3/4" chrome moly heims and be done with it. I've been running around Wellsville for 2 1/2 years with mine, no problems. www.speedwaymotors.com, $15 each. 3/4" swedged steel radius rods $14 each. They also have 11/16 -18 LH tap $30, RH tap $20.
PostPosted: Thu Aug 23, 2007 8:13 pm
I
PostPosted: Thu Aug 23, 2007 9:45 pm
I just thought you liked riding more than wrenching, my bad. :P
