It is currently Mon May 04, 2026 11:34 am
 Post subject: 120cc two stroke buggy
PostPosted: Mon Jun 04, 2007 12:43 am
Check this thing out..
http://www.fieroaddiction.com/buggy.html
I need to build one so when my jets are plugged I can still have some fun
PostPosted: Mon Jun 04, 2007 2:59 am
Hill Climber
Thats crazy. Never seen anything like that before. Have you messed with your carbs yet or are you still pissed at them?
PostPosted: Mon Jun 04, 2007 4:39 am
Brad,
Don't forget to check your fuel pressure and make sure it's not to high. I think that is part of your overall problem. Not the clogged jet problem but the drivabality.
PostPosted: Mon Jun 04, 2007 7:27 am
[quote='hillaholic']Check this thing out..
I need to build one so when my jets are plugged I can still have some fun[/quote]
Having plugged idle jet probs? I fought with mine for 5 years until I finally fixed it. To make a long story short, the problem was in the fuel filters. I used a "sintered bronze" element (that originally was made for a chevy quadrajet- the kind that you un-screw the fitting and put the filter back
PostPosted: Tue Jun 05, 2007 12:47 pm
[quote='D. Marks']Thats crazy. Never seen anything like that before. Have you messed with your carbs yet or are you still pissed at them?[/quote]
I'm still pissed at them. I grounded my buggy and made it stay outside for a week.
PostPosted: Tue Jun 05, 2007 12:50 pm
[quote='Roy']Brad,
Don't forget to check your fuel pressure and make sure it's not to high. I think that is part of your overall problem. Not the clogged jet problem but the drivabality.[/quote]
I
PostPosted: Tue Jun 05, 2007 12:53 pm
[quote='hillaholic']I'm still pissed at them. I grounded my buggy and made it stay outside for a week.[/quote]
:lol: :lol: :lol:
PostPosted: Tue Jun 05, 2007 3:01 pm
[quote='Eric DeBord'] Having plugged idle jet probs? I fought with mine for 5 years until I finally fixed it. To make a long story short, the problem was in the fuel filters. I used a "sintered bronze" element (that originally was made for a chevy quadrajet- the kind that you un-screw the fitting and put the filter back into a hole). I machined some brass fittings and pressed the filter into them, then soldered on the ends. The difference was like night and day. I think I have clean
PostPosted: Tue Jun 05, 2007 3:26 pm
[quote='hillaholic'][quote='Roy']Brad,
I
PostPosted: Tue Jun 05, 2007 6:03 pm
I don
PostPosted: Tue Jun 05, 2007 6:22 pm
The lower the micron rating the better, correct?
PostPosted: Tue Jun 05, 2007 6:47 pm
Yep!
PostPosted: Wed Jun 06, 2007 11:04 am
Yep that would definatly clogg your Pilot jets over and over. I suspect that the screens still let enough crap thru to clog them. It does not take much
Users browsing this forum: No registered users and 11 guests
