It is currently Tue May 05, 2026 4:58 am
PostPosted: Thu May 08, 2008 2:45 pm
before and after the rubberhog got ahold of them,,, yea after several hours
PostPosted: Thu May 08, 2008 9:18 pm
my tires look like the first pic how much can i cut into the tire to get more tread sticking up
PostPosted: Thu May 08, 2008 10:37 pm
I found out the hard way that on boggers the white threads ard only about a quarter inch below the lower surface of the rubber. I just cleanded the sawed off lugs down to the lower surface . I suppose you could use a tire groover then to get closer to the threads . :?
PostPosted: Fri May 09, 2008 12:48 am
Site Admin
Is that the same thing that KY-BC used?
PostPosted: Fri May 09, 2008 6:25 am
Sure is,,,I wanted to get one from Charlie but he was out so I found this one on line
http://www.alltiresupply.com/p-RH-108.html
PostPosted: Sat Jun 07, 2008 11:03 am
Jesse, The best thing to do if you're cutting rubber out from in between the lugs is to use a tire groover and cut just about to the chords (white threads). Try not to cut into them, but go as close to them as you possibly can. Then, use a tire hog to smooth the cuts out or to sharpen the faces of your lugs. This is what I usually do when I cut v-treads.
-Dakotah
JeffClay wrote:
you guys are all gay. Let's have fun in our damn buggies and quit bitching.
-Dakotah/koko
keep on keepin' on!!
PostPosted: Sat Jun 07, 2008 5:08 pm
i dont know if i want to take the chance of going to far i dont have the money for another pair if i do
PostPosted: Mon Jun 09, 2008 8:55 pm
If you accidentally cut into the white cords it will not ruin the tire. If you cut tires, you will have this happen here and there. Don't worry about it.
PostPosted: Tue Jun 10, 2008 9:54 pm
I took those sandpapper style 4" disc for my grinder, punched some holes in them to let the rubber out. (careful not to get them out of balence) Smoothed out a set of 44" swampers in no time,it works great. REALLY SMOKEY!!!
PostPosted: Thu Jun 12, 2008 6:22 pm
like roy said, It will not ruin your tire by cutting into your chords, as long as you dont cut all the way down to where there is only 1 or 2 plys left in that spot. You will know when you hit the chords when you're cutting a tire, You will hear a crunching sound and it will become harder to push the gun through the tire.
-Dakotah
-Dakotah/koko
PostPosted: Wed Jul 30, 2008 12:06 am
Dakota-How do you charge for cutting tires? I have a set of buck-shots and a set of tractor tires that I need cut. My time is limited and I need them done.
Call if you are interested...615-414-7593 Chris
Where did you say the weenie trail is?
