It is currently Tue May 05, 2026 8:42 am
 Post subject: Push Rod Leak
PostPosted: Fri Jul 11, 2008 3:26 pm
I have a pretty good oil leak and it seems to be coming from the case side of one of my push rods. Any suggestions on just replacing a seal or going with new rods etc... if so ... what type? I have heard that stock ones work as good as fancy after market ones (which appears to be what I have). And also what am I going to be looking at to get back up and running? Any input would be greatly appreciated! Thanks!
 Post subject: Re: Push Rod Leak
PostPosted: Fri Jul 11, 2008 3:28 pm
2.00 per tube. use the solid ones they don't leak. you can get them cheaper but the link just shows you what they are.
http://www2.cip1.com/ProductDetails.asp ... C-C10-5371
tear the head off, replace the tube and seals, put head back on, adjust valves, go ride. should be about a hour job. you can do it with the motor in the car.
"Lets go get stupid"
PostPosted: Sat Jul 12, 2008 8:17 pm
Sounds good. Thanks a bunch. I think i am gonna try and make it to jims custom vw swap meet tomorrow and see what i can find.
PostPosted: Sat Jul 12, 2008 9:14 pm
if u got jus 1 or 2 leaking i would buy me a couple aluminum spring loaded,so u dont have to take the head off u will have a chance that the head could leak,not seal back good
PostPosted: Thu Jul 17, 2008 4:35 pm
You mean those arn't supposed to leak?
PostPosted: Thu Jul 17, 2008 8:02 pm
:lol:
