It is currently Tue May 05, 2026 2:50 am
 Post subject: Seats
PostPosted: Tue Apr 15, 2008 2:18 pm
Does anyone on here mount there seats so they lean back farther than normal. This is what im planning on doing so i was wondering if anyone has built a raised crossmember for the front seat mounts. Any ideas and pics would be helpful.
Thanks
Nick
PostPosted: Thu Apr 17, 2008 1:41 pm
Anyone??
PostPosted: Thu Apr 17, 2008 1:44 pm
Hill Climber
I mounted the back of mine on the floor and the front on a bar to raise it a little.
PostPosted: Thu Apr 17, 2008 2:00 pm
WB Videographer and BOTM winner
Mine are mounted on an angled piece of aluminum. Wish they leaned back a little more than they do.
Bryan
PostPosted: Thu Apr 17, 2008 2:11 pm
I have suspension seats and raised the front about 2 inches. It's much more comfortable that way.
PostPosted: Thu Apr 17, 2008 2:47 pm
Tim at Southern buggys might have the angled aluminum plates in stock to mount your seat on an angle.His # is 606-864-2217.
PostPosted: Thu Apr 17, 2008 4:17 pm
I also have suspension seats and my front mounts are 2.5" higher than the rear.
PS: NICK, you need to get out on a ride and check out some buggies in person and take some mental notes. Come to Wellsville in 4 weeks for the party and check out everyones rides. Take pictures, steal ideas.
PostPosted: Thu Apr 17, 2008 4:30 pm
hey Roy its borrow not steal hahah
"Lets go get stupid"
PostPosted: Thu Apr 17, 2008 7:21 pm
I have done this two ways. When my floor was on top of the frame, I put a small 2x4 under the front mounts of each seat. Cheap solution and simple solution.
On my new buggy, I have the floor under the frame so I mounted front tabs flush with the top of the frame and the back tabs flush with the floor. I also used the seat mounts and seat adjusters from Summit Racing.
Good Luck.
Dan
PostPosted: Thu Apr 17, 2008 9:48 pm
I have suspesion seats and they are leaned back by a total of 4.5 inches in the front.
Mark
That's what I'm talking about!
High speed
Low drag
Teflon coated
And ready for action!
PostPosted: Fri Apr 18, 2008 8:54 am
Here is the front mount from my old rail. They are about 3" raised in the front. I really didn’t like them after a couple hours riding my lower back would start hurting because they were leaned to far back causing you to slide forward and no support on the lower back.
I will have pictures of the seats I got from you(I think it was you) soon. I actually cut the back brackets off and welded them flat and it leand them back about 1"
PostPosted: Fri Apr 18, 2008 12:25 pm
How would you slide forward if they were leaned back? Reason i ask i really need these as comfortable as possible due to lower back disc problems. I would think that if the front was raised you would slide back into the seat and it would support your back even better..
PostPosted: Fri Apr 18, 2008 1:15 pm
I didn’t slide far maybe an inch. I don’t know, I thought the same thing when I put them in. They were the all vinyl Corbeau seats and I leaned them for a little more head room. They felt great when I was all strapped in with the 5point harnesses and not driving but after an hour or so of driving my lower back would start aching. I could have been my pedals too low or just a little far away causing me to stretch to reach them. I tried moving my pedals back an inch it did help a little, but if I moved them any further back my knees would be to close to the steering wheel. What I think it was doing was pushing up on my thighs to much and making me slide on the vinyl.
