 Post subject: NEED HELP
PostPosted: Tue Jan 22, 2008 5:19 am
I have a 1976 rear tor. that i am useing for my build and i need to know how to shorten the tor. tubes.To get bigger tires.Can you buy shorter tor. bars?
GET A GRIP
PostPosted: Tue Jan 22, 2008 7:15 am
Go to suspendsion and chassis and look under" vw torsion? "
PostPosted: Tue Jan 22, 2008 11:04 am
Replace them with a set from a swing axel setup. They use shorter torsions and the caps are flush. You will need to use the swing axel spring plates and shorten them to fit your IRS trailing arms.
PostPosted: Tue Jan 22, 2008 11:15 am
If you have the money buy extended trailing arms and you dont have to fabricate anything.Plus they will give your buggy a nicer ride.
aaron
PostPosted: Tue Jan 22, 2008 11:16 am
[quote='dunebuggy79']If you have the money buy extended trailing arms and you dont have to fabricate anything.Plus they will give your buggy a nicer ride.
aaron[/quote]
what Aaron said!!! you can pick some up on this site. (try Dean Marks)
