It is currently Mon May 04, 2026 8:54 am
 Post subject: Noises
PostPosted: Wed Aug 14, 2013 7:32 pm
My super awsome buggy is making a noise I'm going to try and liturally describe "that's with words "what it sounds like it goes at about 35 to 4 grand Adadad Adadad if you could see and hear my daughter now she does the noise perfect any help
This one time at wellsville
 Post subject: Re: Noises
PostPosted: Wed Aug 14, 2013 7:52 pm
Are you rubbing it and saying goochie goochie goo. :roll: :roll: . Chad :mrgreen:
PostPosted: Wed Aug 14, 2013 8:02 pm
Is there oil in it?
PostPosted: Wed Aug 14, 2013 8:11 pm
mine goes baa baaaaaaaa baa a baaaaaaaaaaaaaaa!
PostPosted: Wed Aug 14, 2013 8:28 pm
Just throwing a guess out to left field. For internal sounds, Stick a fuel hose in your ear and touch different sides of the motor and listen all over including flywheel. Disconnect belt would be better for hearing and rag over exhaust. A tooth missing on 1st gear main shaft will make a small knock while in neutral.
PostPosted: Wed Aug 14, 2013 9:54 pm
You ain't right. Having said that, that was too funny.
PostPosted: Thu Aug 15, 2013 10:32 am
Just mash on it you will find then!
PostPosted: Thu Aug 15, 2013 10:43 am
Last time I had 4 adadad noised coming from my commuter car and it turned out that them walmart tires went bad and had loose internal threads (60-70% thread left). Went by South Eastern tires and all the Adadad got deported.
PostPosted: Fri Aug 16, 2013 12:01 am
Haha if I know Sawyer its already been done aboone. :mrgreen: :shock:
