 Post subject: Air Compressor
PostPosted: Tue May 22, 2012 9:37 pm
Looking for an air compressor, it would be our first one. Have been checking out tools today, impact wrench 1/2" 3/4", sand blasting, maybe* grinder, maybe* the tin snips seem really useful for body pannels. Then just general uses for it. I was searching around and found what seems like a pretty nice air compressor. Little bit pricey, pretty big, and its stationary which is a good thing. Also made in the USA! Have my mom half convinced. Rating seem half good half bad, could be luck of the draw or poor use.
http://www.craftsman.com/craftsman-prof ... ockType=L6
Tell me what you think?
WTFO
Loud pipes save lives.
 Post subject: Re: Air Compressor
PostPosted: Tue May 22, 2012 10:08 pm
I have the same tank. Just the cheaper "non professional" version. The tank is only the beginning of the costs. Quality tools will quickly add up.
The three tools I use the most in the garage - 1/2 inch impact, 1/4 inch socket and my small hand grinder. Make sure to get a good set of impact sockets to go with the impact wrench.
PostPosted: Wed May 23, 2012 1:09 am
this is what i have just an older model and like it pretty well, but at times i wished i had the 2stage with 80 gal tank like a buddy of mine has
http://www.lowes.com/pd_221565-14989-LL ... nfo=Kobalt
PostPosted: Wed May 23, 2012 1:37 am
best thing i ever had in a shop is the battery powered impacts makes everything alot faster and more easy use them on almost any nut and bolt on the buggy and comes in big handy out in the woods for changing cv,s or whatever
PostPosted: Mon Jun 25, 2012 10:30 pm
Picked it up on sat, $503 including tax. Saved like $250 bucks.
Bought an impact wrench 1/2 and saved like $40.
http://www.craftsman.com/craftsman-1-2-in-heavy-duty-impact-wrench/p-00919984000P?&prdNo=9&blockNo=9&blockType=L9
Also bought 2 packs of impact sockets, SAE and Metric deepwells down to $40 each, from $90.
http://www.craftsman.com/craftsman-12-pc-impact-socket-set/p-00915886000P?vName=Power+Tools+%26+Equipment&cName=Equipment&sName=Compressors+%26+Air+Tools&prdNo=8&blockNo=8&blockType=L8
I figure im going to plumb it with black steel pipe, pvc is just dangerous, copper $$$, and pex doesn't make the water condense well enough.
Not exactly sure how to wire it though. http://www.justanswer.com/electrical/4plxb-230-volt-compressor-installing-when.html and don't really understand this? Could someone explain?
WTFO
Users browsing this forum: No registered users and 8 guests
