It is currently Mon May 04, 2026 11:29 am
 Post subject: Good or bad idea???
PostPosted: Tue Jun 05, 2012 2:42 pm
Pro-Comp Race Ready Eng. Kits
This kits contains all New parts Forged piston & cylinder kit, heavy duty oil pump, main, rod & cam bearings, performance camshaft, lightweight lifters, 4340 gland nut & washer, big bore engine gasket kit & silicon rear main seal, Nitrided 4340 Chromoly forged billet crankshaft, 4340 H beam connecting rods, Stoker AS41 dual by-pass engine case, Mini "D" port heads, 3/8" Chromoly pushrods, 4140 Chromoly 8mm case stud kit, adjustable O-Ring aluminum pushrod tubes, univ. engine case hardware kit, 40 piece engine lock nut kit and crankshaft gear assembly kit.
02-2027-1 2027CC RACE READY ENG KIT 78.8MM X 90.5MM $ 2977.95
02-2095-1 2095CC RACE READY ENG KIT 78.8MM X 92.0MM, KIT $ 2977.95
02-2110-1 2110CC RACE READY ENG KIT 82MM X 90.5MM, KIT $ 2977.95
02-2161-1 2161CC RACE READY ENG KIT 84MM X 90.5MM, KIT $ 2977.95
02-2187-1 2187CC RACE READY ENG KIT 78.8MM X 94.0MM, KIT $ 2977.95
02-2180-1 2180CC RACE READY ENG KIT 82MM X 92.0MM, KIT $ 2977.95
02-2234-1 2234CC RACE READY ENG KIT 84MM X 92.0MM, KIT $ 2977.95
02-2275-1 2275CC RACE READY ENG KIT 82MM X 94.0MM, KIT $ 2977.95
02-2332-1 2332CC RACE READY ENG KIT 84MM X 94.0MM, KIT $ 2977.95
 Post subject: Re: Good or bad idea???
PostPosted: Tue Jun 05, 2012 3:50 pm
I would buy a complete motor before I done that I priced that 2500 for 4500 and all u have to do to it is bolt it on and go it has clutch and pressure plate
PostPosted: Tue Jun 05, 2012 4:04 pm
That's to much for me. Pockets ain't that deep. Wish I could
PostPosted: Tue Jun 05, 2012 7:01 pm
Were are these kits from ???
PostPosted: Tue Jun 05, 2012 7:35 pm
This would really depend on your skill and ability to rebuild an engine. If you have done it several times and know what you are doing, the kit should work fine. If you have not built several engines, that is a lot of money to spend and you will most likely mess something up.
I believe you are looking at Dans Performance Parts... If so, you might also consider the SCAT Long Block. For another $200, you can get the 2027 Long Block instead of the kit.
PostPosted: Tue Jun 05, 2012 7:53 pm
With heads and all !!
I wouldnt trust my beast to be with junk economy crap. Do they give details of makes of parts.
PostPosted: Tue Jun 05, 2012 9:24 pm
Go front wheel drive with ford irs diff and be done with all them carbs, clutches, starters, bus trans, 4 diffs,oil coolers,headers,cams,etc etc. :D
PostPosted: Tue Jun 05, 2012 10:30 pm
I have built a few and I was lookin for opinions ab the parts compared to the empi stuff. Yea dans is were that was from
PostPosted: Wed Jun 06, 2012 9:07 pm
I believe they are all SCAT parts. I have not heard anything bad about SCAT. I am not a fan of EMPI. I had to rebuild my engine twice because of crappy EMPI failures. I personally prefer CB performance.
Users browsing this forum: No registered users and 8 guests
