It is currently Mon May 04, 2026 8:52 am
 Post subject: alternater olny 8v
PostPosted: Thu Apr 22, 2010 7:25 pm
i have a 75 amp alternater was working fine but today a had the top of the carb off to clean it and it fell on the the + wire on the alternater and we had some sparks would this miss something up inside bc im olny getting 8v out of it now. need some help thanks
 Post subject: Re: alternater olny 8v
PostPosted: Thu Apr 22, 2010 11:31 pm
Check the charge light that you should have installed. it may have blown that.
PostPosted: Fri Apr 23, 2010 11:43 am
My original alternator had a piece of cardboard under the battery lead. After a few years the cardboard fell apart and caused a direct short. I took it to a local rebuild shop and they said it blew everything inside and wasn’t rebuildable. Hopefully that’s not the case with yours. Like nitro said you need to have an idiot light that’s working. If it’s a one wire alternator you need to have 12volts to excite (turn on) the regulator. So if the idiot light is burnt out it can’t complete the circuit and turn on the regulator. If all that is good take it to a rebuild place and have them check it. Could be a 50 cent diode.
PostPosted: Fri Apr 23, 2010 4:48 pm
do i need a charge light i dont now. is it hard to take one apart and look at or do i really need to take it someplace.
PostPosted: Fri Apr 23, 2010 4:53 pm
The charge light will be mounted up front where u can see it.
Try this.
http://www.woodsbuggy.com/index.php?opt ... =18&t=3518
PostPosted: Fri Apr 23, 2010 7:50 pm
mine does not have the DF or D+ on it does the one with the nut run to the + side of the bat. and would not having the light keep it from putting out 12V
PostPosted: Fri Apr 23, 2010 9:27 pm
Yes, the one with the nut goes to the power feet to the starter or to the + of the battery. Then the small spade goes to one side of the idiot light, and then the other side of the idiot light goes to ignition on.
Call me if you need help I can explain it a little more over the phone. I’ll be up till 12 or so tonight.
Brad 440-225-9063
PostPosted: Tue Apr 27, 2010 7:11 pm
Brad 440-225-9063
thanks alot for the offer to talk me throw it but i hooked up the wire today works great now. :D
