PostPosted: Sun Feb 14, 2010 2:47 pm
Looking for opinions on the best starters available,what they cost and where to buy? 091 trans is what i will need it for. Thanks
 Post subject: Re: Best starter?
PostPosted: Sun Feb 14, 2010 3:13 pm
My personal experience is to use a 3 rib bell or have your 091 milled to accept a late model Beetle diesel for automatic,, you will need to modify the bolt holes on the starter a little. Make sure the starter has 9 teeth.
I bought this one on ebay. It whizzes my 6 banger like crazy.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
PostPosted: Fri Mar 26, 2010 8:25 am
I have a side shift 6 rib with an older 091 bellhousing. What years were the 091 pre water cooled busses? When lookink at startes at the parts store what should i be looking up? Thanks.
PostPosted: Fri Mar 26, 2010 11:23 am
As bug said you need to mill 3/8 off the face where the starter bolts on then you can run a car starter or a automatic starter or a high torque 1. the reason for running a 3 or 5 rib bell houseing is that if you break yours you can pick another one up about anywhere or a 3/8milled 6 rib.
PostPosted: Fri Mar 26, 2010 1:52 pm
my cars together and i'm not taking it back apart to mill bellhousing. what years do i need tro ask for? Thanks again.
PostPosted: Fri Mar 26, 2010 7:36 pm
can you just mill 3/8 off the starter face?
