It is currently Mon May 04, 2026 10:15 am
 Post subject: coil problems
PostPosted: Sun Oct 25, 2009 7:09 pm
I have got a bad problem with coils cracking at the top of the tower. i have went threw at least 6 or more in the last 2 years, my set up is a pro comp dist. blue max wires, off road msd6,the last coil was a msd high vibration,i have cracked blasters,mallorys,boshs u name it. i have tryed 2 msd boxs. tryed external resistors.EVERY THING IS WIRED RIGHT!!!!!!!!!!!!!!!!GOOD CONNECTOINS!!!!!!!!!!!!!!!!!!!! This seems to be worse in damp weather. any help or ideal would be appreciated thanks.
 Post subject: Re: coil problems
PostPosted: Sun Oct 25, 2009 7:23 pm
Where do you have it mounted?
PostPosted: Sun Oct 25, 2009 7:35 pm
ON THE BAR BETWEEN THE SEATS AND MOTOR TO THE PASSANGER SIDE AWAY FROM ANY HEAT. I SHOULD ALSO TELL YOU THAT THE COIL DOES DOT SEEM TO BE HOT TO THE TOUCH,AND THIS IS NOT A VW BUT A 2.3 FORD. THANKS
