It is currently Sun May 03, 2026 2:06 pm
 Post subject: Bad Alternator
PostPosted: Mon Mar 23, 2009 7:40 pm
Would a bad alternator prevent the idiot light from coming on when the key is turned on but not started? It's on a WC but I wired it the same as an AC. Alternator isn't charging and thought I would pull it off and take it and get it checked but was curious what you all might think.
Bryan
 Post subject: Re: Bad Alternator
PostPosted: Mon Mar 23, 2009 9:38 pm
maybe a wire came undone somewhere between your ignition and alternator or your idiot light just went bad for some reason but it should of stayed on the entire time if your alternator was bad just like in a car
PostPosted: Mon Mar 23, 2009 10:38 pm
That's what I was wondering. Maybe alt would be last thing to check.
Thanks.
Bryan
PostPosted: Tue Mar 24, 2009 5:36 am
is it a single wire alt.?
PostPosted: Tue Mar 24, 2009 8:44 am
It has a plug with only one wire hooked up then it has the wire going to the battery.
Bryan
PostPosted: Tue Mar 24, 2009 9:56 am
Needs to be wired like this for an AL82 Bosch single wire alternator.
