oil temp/pressure sender install
http://woodsbuggy.com/phpBB3/viewtopic.php?f=18&t=4976
Author:  kbowling [ Wed Oct 29, 2008 1:36 pm ]
Post subject:  oil temp/pressure sender install
Hi all,
New to site. I'm trying to mount oil pressure and oil temp. sending units on my a/c 1641cc. What is the easiest way to accomplish this...run a tee adapter from oem sender location, or run each from a separate location? Both gauge senders are electrical (Sunpro). Thanks in advance.
Author:  turboblue [ Wed Oct 29, 2008 2:37 pm ]
Post subject:  Re: oil temp/pressure sender install
kbowling wrote:
Hi all,
Welcome to the site.
The oil temp won't do you much good in the place you get your pressure.
That sender needs to be in flowing oil to get a good read.
I'd put it in a cooler line somewhere.
The pressure sender can be screwed in to the pressure port but I would use that along with the stock sender for the idiot light.
If the light comes on, you will notice that before you notice a gauge that is dropping.
The light warning tells you to confirm the gauge reading and take appropriate action.
That set-up will require the T you mentioned.
Author:  kbowling [ Wed Oct 29, 2008 3:42 pm ]
Any particular place in the external oil cooler line...maybe close to where the oil exits the block, or does it really matter on sender location?
Author:  turboblue [ Wed Oct 29, 2008 6:15 pm ]
I'd probably put it after the cooler.
You can at least see what the temp is of hte oil returning to your engine.
Author:  kbowling [ Wed Oct 29, 2008 9:21 pm ]
Thanks for the info...I'll go with your advice.
Author:  volksdude2007 [ Sat Dec 13, 2008 1:38 am ]
any body wanna put a diagram up for this one or photo of someone that has it done already for the idiot light and the oil temp
