It is currently Sun May 03, 2026 5:11 pm
 Post subject: turn signal
PostPosted: Wed Jul 09, 2008 1:21 pm
We are going to put turn signals on a bug and was wondering how to wire them up. We are going to use a three way toggle switch and two flashers.
Thanks cyle
 Post subject: Re: turn signal
PostPosted: Wed Jul 09, 2008 3:36 pm
Thanks cyle
That's how we do it.
Switch needs to be off in center, on left or right.
Power up switch, left side of switch goes through one flasher then to the left front and rear lights.
Right side of switch goes through the other flasher then to the right front and rear lights.
PostPosted: Wed Jul 09, 2008 6:04 pm
its simple just call me i will tell ya how
PostPosted: Tue Jul 29, 2008 7:23 pm
Thanks cyle
You can use a single flasher by just flashing the main hot wire.
PostPosted: Wed Jul 30, 2008 10:40 am
TrackerCasey wrote:
Thanks cyle
Then the flasher is powered up constantly.
PostPosted: Thu Jul 31, 2008 8:31 am
I wouldn't think so, as long as it's an open circuit it won't do anything.
As long as you're going from the batt+ -> flasher-> switch. Just don't ground the center position of the switch (wouldn't want to do that either way).
Get me that hammer, pronto!
PostPosted: Thu Jul 31, 2008 3:50 pm
Yeah that's right now that I thing about it.
Either way works......... 8)
PostPosted: Thu Aug 14, 2008 12:46 am
Depending on why you want blinkers, you might want to consider a $14 universal blinker switch. If you are hoping to make the buggy street legal, most states require hazard flashers. I do not think you will be able to do hazards with toggle switch idea.
In addition, you can run a single tail lights integrated in with the brake switch. Less lights to buy and mount on the back of the buggy.
Just another idea.
Dan
