PostPosted: Wed May 07, 2008 2:20 am
Anyone have any experience with these setups? I am thinking about getting one to wire my rail up. Seems like a good deal 159 for the rollbar mounted one and comes with all the wiring and relay setup etc. also waterproof and says ideal for open cockpit setups. thanks for the feedback guys.
Check out this link
http://www.jegs.com/i/ARC/116/4000R/100 ... 7613|10405
"Lets go get stupid"
PostPosted: Wed May 07, 2008 7:33 am
that thing is cool, I like the ability to change the operation to momentary, use it for your starter....
by the time you get a box, switches, relays, etc. for a regular set-up........
the way I read it it's warrantied for life...looks like a good deal to me, go for it!
Mike
Got Honda?
PostPosted: Tue Jul 22, 2008 7:48 am
Willies new buggy has one in it, I saw it at D&k. Nice looking system, the switch box is detatchable so you can take it with you. I plan on putting one in the buggy I am building
PostPosted: Tue Jul 22, 2008 8:40 am
haha yea he called me about it. he fell in love with that thing at wellsville. so far it has worked flawless for me. i power wash it and everything haha.
PostPosted: Tue Jul 22, 2008 11:00 am
I like the fact that it eliminates having a switch box or panel. One less thing to peel your onion in a crash!
If yours and WIllies still work this time next year, I might have to splurge on one! :lol: :wink:
Larry
PostPosted: Tue Jul 22, 2008 11:47 am
Hey Larry it is also a lifetime warranty.
The only thing I did was wrap the thin cable in black electrical tape just to sturdy it up a bit.
Kyle
PostPosted: Tue Jul 29, 2008 4:12 pm
The system looked well built and pretty simple to hook up. Just heed a water tight area for that relay panel.
PostPosted: Tue Jul 29, 2008 4:15 pm
not perfect water tight but on the trail it never gets wet. when i power wash i get a little moisture in the bottom of the box but i just leave the lid open during the week. the panel sits up off the bottom also about 2 inches same as msd. no problems yet 100% perfect.
PostPosted: Tue Jul 29, 2008 4:19 pm
nice lookin set up man!! Gives me some ideas. I need a space like that to house my msd and also a fuel injection cpu. Yers looks good! Did u silicone the holes for the wires to run through
PostPosted: Tue Jul 29, 2008 5:03 pm
yep i siliconed all the holes but the actual toolbox is not perfect water tight.
PostPosted: Fri Sep 05, 2008 2:32 pm
i did the same thing with my regulator, solenoid, and batt. cut-off. any marine box (flare type), waterfowl ammo box, or watertight tackle box will work (gander mountain has all 3). the i used waterproof conduit fittings to run the wires through the side of the box without nicking the insulation, tape the outside up and no leaks.
http://images.lowes.com/product/convert ... 8955sm.jpg
PostPosted: Wed Sep 24, 2008 10:55 am
Does this allow you to start your buggy as well, I do not see where it could be used to start your buggy? Does anyone have any pics of this panel mounted on there buggy? thanks Donnie
PostPosted: Wed Sep 24, 2008 11:24 am
Don't know about the starting part but here is a pic of the one Kyle installed in his buggy.
He might be able to help you out with any questions.
Bryan
PostPosted: Wed Sep 24, 2008 5:47 pm
I like the set up, it has a relay board that will run anything that can be run from relays. And yes it will start it too.
PostPosted: Sun Oct 19, 2008 11:29 pm
i dig mine big time
PostPosted: Sun Mar 01, 2009 1:04 pm
mine still works fine and plus it's cool as hell
PostPosted: Mon Mar 02, 2009 12:47 am
same here willie told ya it was slick, perfect for a buggy.
o and my panel is mounted with a ziptie around rollbar, it only weighs maybe 20 grams.
