 Post subject: Starter options ?
PostPosted: Fri Nov 08, 2013 10:19 pm
What are my options for a starter for a 6 rib bell ?
Cranking over a Subaru .
 Post subject: Re: Starter options ?
PostPosted: Sat Nov 09, 2013 12:14 am
either a high torque starter for a 091 has to be the longer one for six rib of course or if swaping do the Subaru bell housing stock Subaru clutch pressure plate starter that's about your only options I have used a stock starter but they are sluggish once u start to run them turns very slow till your motor is cool
*subiepower*
PostPosted: Sat Nov 09, 2013 12:26 am
http://www.ebay.com/itm/VW-Sandrail-High-Torque-Starter-for-Type-2-091-094-Bus-Transmission-IMI104N-/261157025776?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cce2bf7f0&vxp=mtr
this is the build were he did the bell housing instead of adapter
viewtopic.php?f=23&t=9147
*subiepower*
PostPosted: Sat Nov 09, 2013 8:16 am
Here is an old post with some good info..
http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=109&jfile=viewtopic.php&f=18&t=8032&hilit=hi+torque+starter
Please note, I said the post was old, not the people in the post. :shock: :lol: :shock:
PostPosted: Sat Nov 09, 2013 10:25 am
Best deal out the there
http://www.woodsbuggy.com/viewtopic.php?t=11144Starters
PostPosted: Sat Nov 09, 2013 11:40 am
I went to o'rileys 40.00 with a lifetime warranty. And it works really good
PostPosted: Sun Nov 10, 2013 12:24 am
Too bad the subie one wouldn't work I have one here u can have !!
PostPosted: Sun Nov 10, 2013 12:40 am
I used a 3 rib bell and 74 autostick starter on my suby project. Worked great
PostPosted: Sun Nov 10, 2013 3:21 am
A Subaru starter does work if you buy the small car bell along with the clutch and pressure plate , just somewhere else you got to bite the bullet.
PostPosted: Tue Dec 10, 2013 8:48 am
I did it Firebugs style, (5 rib)
For a 6 rib, you could use a adaptor and a stock VW diesel starter.
About half way down this page.
Norm
http://www.westyventures.com/parts.html
