It is currently Sun May 03, 2026 7:16 am
PostPosted: Tue Aug 24, 2010 12:48 pm
ok i have the motor and ecm and harness and also all the wiring diagrams....
my qustion is can i take the ecm diagram and just keep all the things needed to make it run and put bat to bat and ign and what not strait from the comp? or is there more to it?
PostPosted: Tue Aug 24, 2010 12:54 pm
I think there is more to it. For one thing you will need to use relays in some places. Not sure what else. Call Tom.
PostPosted: Tue Aug 24, 2010 1:34 pm
relays on the fuel pump, fans, and what not ... but i just want the computere to run the motor ill do everything else seperate???
PostPosted: Tue Aug 24, 2010 6:07 pm
what i do is( if you can ) get engine running and then start deleted stuff one at a time... then make sure it still runs..
PostPosted: Tue Aug 24, 2010 6:39 pm
the motor has all ready been pulled...
PostPosted: Sun Aug 29, 2010 12:41 pm
well if it helps i can get wiring diagrams for you through all data... just let me know
