It is currently Mon May 04, 2026 12:50 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Mon May 30, 2011 10:21 am
My modified ebay starter is still spinning with lightning speed,,,I have bought some used starters and modified them also but make sure they have a D or P on the end, as in 020 911 023D. they have 1.8 kw power,,the ebay China starter is 2.0 kw,,link below:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
PostPosted: Sat Nov 26, 2011 6:50 pm
These things rock! I had always ran a 6volt starter with 12 volts and those work really well, but not as fast as these!! Thanks for the find..
PostPosted: Thu Oct 11, 2012 9:05 pm
Bump
PostPosted: Mon Dec 17, 2012 12:08 am
How hard is it to find the right one
If its on the internet its got to be true they can't put any lie's on the internet
PostPosted: Mon Dec 17, 2012 9:46 am
its not hard at all click on the link he got and hit buy it now! :mrgreen: :twisted:
we are running a couple used one off regular gas engines and they work fine to.
PostPosted: Mon Dec 17, 2012 5:58 pm
I'm trying to be a tight azz :D
PostPosted: Wed Jan 02, 2013 1:33 am
Firebug wrote:
hillaholic wrote:
That is IT,,,I actually bought mine from a diff person,,,this is the one I talked to him about but he upgraded to the one just like above,,,
call him and tell him you want the one like this but 2.0kw,,9 tooth,,ccw. I asked for a number but he has not got back yet,,or just get the one you found,,,or go to pullapart,,,,compare numbers,,,
you need to elongate the bolt holes, I used the 3rd bolt hole for my ground,,sad grinding it voids warrantee ,, Im off to New Mexico for class,,will try to log on out there,,,good luck,,,,,I love the starter,,it is wicked.
Also very important,,,,I use a THREE RIB BELL HOUSING
ive read the post through a couple of times, am i correct that this will not work on a 5 rib?
ya cant beat fun!
PostPosted: Wed Jan 02, 2013 6:04 am
If you still have the 002 bell housing still on the 5 rib . yes it will work.
PostPosted: Fri Jan 25, 2013 9:46 pm
Bump
