Hey Hippie,
Not sure if anyone actually answered your question. The Brake switch is a pressure switch that goes anywhere in your brake lines. SubySteve is correct, you will need a T to install the brake switch but be careful what switch you buy and make sure to match the T. I believe most brake switches are 1/8 pipe tread but your break lines are probably the standard VW bubble flare. That means you need a mismatch T with two bubble flare and one pipe thread. You will probably have a hard time finding that T in any advanced auto store.
I would give one of the woodsbuggy.com sponsors a call. I usually call Tim at SouthernBuggies or Gary at Davis Racing. Both of these guys will help you out and make sure you get the right parts.
Good Luck..
_________________ Woodsbuggy forum is now on the Tapatalk Mobile app... (iPhone, iPad and Android devices)
