 Post subject: alternator help asap
PostPosted: Fri Jul 31, 2009 2:26 pm
I put a switched from gen. to alternator 2 weeks ago, worked fine, Now the idiot light comes on like it should, But doesnt go completely out, It stays on very dim at idle Ideas? Thanks for the help
"IT IS WHAT IT IS"
 Post subject: Re: alternator help asap
PostPosted: Fri Jul 31, 2009 3:36 pm
Stock crank pulley, or power pulley or dry sump?
Whats your idle rpm?
Mine have all always done that (until I switched to Kidd1's super small alt. pulley), but I've never ran a stock crank pulley.
PostPosted: Sun Aug 02, 2009 9:46 pm
I have a volt gauge in my car instead of a light and at idle my alt is not at full potential. With just a little rpm it is better and i do use an underdrive pulley.
PostPosted: Mon Aug 03, 2009 3:57 pm
Install at least a 10 gauge charge wire from the large terminal on the alternater to the B+ on the Battery. Your charging wire is too small. Oh yea I told you that allready! :wink: :mrgreen:
PostPosted: Mon Aug 03, 2009 8:48 pm
I always have the same prob. I had to rev it up to get my light to go out, after that it stayed out. I'll have to try the heavier ga. wire.
PostPosted: Tue Aug 04, 2009 7:55 am
yea yea! i kno! Thanks for the help ody
"IT IS WHAT IT IS"
