It is currently Sun May 03, 2026 12:52 pm
 Post subject: voltage spikes
PostPosted: Fri May 16, 2014 12:47 am
1835 vw, my voltage will spike to 18 plus volts, might run normal at 14v then rapidly jump to 18v. It might be normal for 10 minutes, then spike for 5 to 10 minutes. I've checked and cleaned all terminals. On my alternater there is a device mounted to the top I assume this would be the regulator, removed from my alternater cleaned, brushes looked good, also noted diodes. What would think the problem most likely is the alternator of this unit on top the alternator?
Thanks
 Post subject: Re: voltage spikes
PostPosted: Fri May 16, 2014 11:27 pm
My alternator is a Motorola, is it worth taking the chance at purchasing a regulator for $50.00 or should I purchase a Chinese product?
PostPosted: Fri May 16, 2014 11:40 pm
I suggest checking all your grounds making sure everything is grounded properly.
