It is currently Sun May 03, 2026 1:51 am
 Post subject: Oil idiot light
PostPosted: Tue Feb 25, 2014 12:02 am
My oil idiot light comes on when I turn ignition on and then goes out...
But if I unplug wire from sending unit it doesn't come on? Am I missing something? Bought a new sending unit and still does the same thing.
Sent from my SCH-I605 using Tapatalk
 Post subject: Re: Oil idiot light
PostPosted: Tue Feb 25, 2014 1:35 am
1st of all I noticed Sunday that your fan belt is very loose. I could see the belt actually leaping over the pulley as you reved. And the oil wire needs to go from the sender , thru the lite, and then to the "run" or "accessory" side of the key switch. I guess you have it going to "start". Get a Top Cog belt from Autozone. They may have to order it, but they are the best.
PostPosted: Tue Feb 25, 2014 4:43 am
Both of my buggies had the light come on when ignition got turned on then went off i thought that was normal
PostPosted: Tue Feb 25, 2014 8:57 am
Not if the motor is not running
PostPosted: Tue Feb 25, 2014 11:55 am
Ok I'll check it
And DD thanks for the tip and I bought a gates yesterday. lol
PostPosted: Tue Feb 25, 2014 1:40 pm
Oil light should come on with ignition turned on. It goes out after the engine is running and the oil pressure builds high enough to break circuit to ground.
PostPosted: Tue Feb 25, 2014 3:59 pm
But shouldn't it come on if you unplug the sender?
PostPosted: Tue Feb 25, 2014 4:11 pm
There is no ground if sending unit is unplugged so no light. if you want to check it unplug it and touch it to the block light should come on when wire is grounded.
kydecoy
Work Hard Play Harder
Ok I'll try that. Thanks
