Well even though it turned out looking like a battle bot instead of a console I thought I would show my current progress... I should have it all in this weekend...
I am trying to figure out how to hook up the Ignition Switch now so I can be done with it... So far I think this is right:
I am guessing its: (I might be all wrong here)
#1 Red - Battery - Same Red Of Harness (Both go to the same one)
#2 Yellow/Red Stripe - Start - Purple of Harness
#3 Orange - Accessory - Brown Of Harness
#4 Purple - Ignition - Orange of Harness
#5 Purple - Ignition - Pink Of Harness
#6 Red - Battery - Same Red Of Harness (Both go to the same one)
I am guessing based on this info:
and
http://www.colehersee.com/assets/files/ ... dD-613.pdf And the plug order is:
#1 Red - Battery
#6 Red - Battery
Harness:
Brown - Ignition Switch Accessory
Red - Ignition Switch Power
Orange - Ignition Switch Ignition
Pink - Coil
Purple - Ignition Switch Start
What do you guys think? Will my diagram work... I will be researching this today... hope to solder it up tonight.
