| 372 HP STREETABLE ECOTEC http://woodsbuggy.com/phpBB3/viewtopic.php?f=17&t=9997 |
| Author: | tw9294 [ Sun Aug 01, 2010 11:06 am ] |
| Post subject: | 372 HP STREETABLE ECOTEC |
Ecotec with large s/c,75mm camaro throttle body,comp cams and header. 372 hp and 291 ft lbs tourqe. http://image.hotrod.com/f/18935335/hrdp ... lt_ons.jpg Stock s/c on right and eaton mp90 middle and eaton 1900tvs on left. http://image.hotrod.com/f/19359846/hrdp ... lt_ons.jpg http://image.hotrod.com/f/18935443/hrdp ... lt_ons.jpg |
| Author: | Stevo [ Sun Aug 01, 2010 11:40 am ] |
| Post subject: | Re: 372 HP STREETABLE ECOTEC |
Thats cool. What tranny would hold up to that kinda power?? |
| Author: | Baddvw [ Sun Aug 01, 2010 5:59 pm ] |
I would say the MD4D Mendeola will be able to hold that kind of power, but very PRICEY http://www.kcrtrans.com/mendeola.html |
| Author: | ImmortalSoul219 [ Sun Aug 01, 2010 8:40 pm ] |
"ECOTEC POWER" I got 1 in my buggy and now Im collecting parts to put one in my MazdaSpeed Protege. |
| Author: | Dave_in_Florida [ Wed Aug 04, 2010 8:50 pm ] |
why would you do that? The Duratec motor is just as good as the Ecotec, and quite a bit smaller too. |
| Author: | nitro_mudder [ Thu Aug 05, 2010 12:53 pm ] |
This is the problem with watercooled, the trannies that will handle it cost a ton. Gotta be a better trans out there. |
| Author: | tw9294 [ Thu Dec 02, 2010 8:50 pm ] |
Baddvw wrote: I would say the MD4D Mendeola will be able to hold that kind of power, but very PRICEY http://www.kcrtrans.com/mendeola.html So you could buy this trans for aprox the same cost as a NICE 2500 vw motor |
| Author: | ImmortalSoul219 [ Thu Dec 02, 2010 10:56 pm ] |
Dave_in_Florida wrote: why would you do that? The Duratec motor is just as good as the Ecotec, and quite a bit smaller too. Duratec is an ecotec wanabe. |
| Author: | passat2800 [ Fri Dec 03, 2010 12:24 am ] |
STOP!Yall threw away the best trans when yall unbolted the Ecotec out of the car!Run a diff into a diff!Nothin to buy.Power and gearing will be outrageous. Yes, I am the Jahovah witness that won't go away. |
| Author: | ImmortalSoul219 [ Fri Dec 03, 2010 8:15 am ] |
Run the ecotec trans into a rear diff? I wonder how long the stock trans would hold up. |
| Author: | PhillipM [ Fri Dec 03, 2010 4:06 pm ] |
Fetch a UN5 over from the UK, sorted. |
| Author: | davehix [ Fri Dec 03, 2010 4:48 pm ] |
nitro_mudder wrote: This is the problem with watercooled, the trannies that will handle it cost a ton. Gotta be a better trans out there. Hell the money you guys save by not building ac should justify money for the trans. |
