What fuel pump you running?
http://woodsbuggy.com/phpBB3/viewtopic.php?f=17&t=9421
Page 1 of 2
Author:  ImmortalSoul219 [ Wed May 05, 2010 7:22 pm ]
Post subject:  What fuel pump you running?
Just wondering what fuel pumps you guys are running and your reviews on them?
I had a walbro lph 255 that quite on me after only putting it in back in fall. Also you could hear it humming over the engine.
So what are you guys running?
Author:  Firebug [ Wed May 05, 2010 7:28 pm ]
Post subject:  Re: What fuel pump you running?
http://www.summitracing.com/parts/SUM-G3138/
Author:  Huey [ Wed May 05, 2010 8:27 pm ]
I use the ford F150 fuel pump. Been running for 3 or 4 years now. See below.
The external pumps used in Ford F150 fuel injected trucks from the 89-93 model years are Delco EP286. At 12 volts, the operating pressure is 70-95 PSI with 36-40 gals per hour. The biggest Delco pump is the EP424, which is 75-90 PSI at 40 gals per hour. EP 268 is a GM# 25117086, EP 424 is a GM# 25176156."
info came from here ---> http://www.megamanual.com/v22manual/minj.htm#supply
Author:  MickeyMouse [ Wed May 05, 2010 8:59 pm ]
I like to keep it simple.. Stock Fuel Pump works fine for me.. If I go to dual carbs, maybe I will upgrade.
Author:  tw9294 [ Wed May 05, 2010 9:22 pm ]
Ditto. of course i only have a few hours on it.
Author:  ImmortalSoul219 [ Thu May 06, 2010 6:38 am ]
how loud are your pumps? I didnt like being able to hear it over the engine.
Author:  RaceBugg1098 [ Thu May 06, 2010 8:07 am ]
Walbro 255
Author:  ImmortalSoul219 [ Thu May 06, 2010 9:29 pm ]
RaceBugg1098 wrote:
Walbro 255
Have you had any problems with your Walbro?
Author:  perrib [ Fri May 07, 2010 12:58 am ]
Stock fuel pump. The stock pump is enough to feed dual 48 IDAs.
Author:  Firebug [ Fri May 07, 2010 6:04 am ]
What water cooled engines uses dual carbs? Most of them are EFI.
Author:  ImmortalSoul219 [ Fri May 07, 2010 6:43 am ]
yea this is a question for the water guys out there.
Author:  perrib [ Fri May 07, 2010 9:36 am ]
Sorry about that. Were you using a filter between the fuel tank and inlet of the pump?
Author:  ImmortalSoul219 [ Sun May 09, 2010 7:48 am ]
i have my fuel filter before the pump. I have a later vw golf fuel filter which is huge with the theory that since I dont have any baffles in my tank or even a sump that on hard hills I might be starving my engine. So with this big fuel filter it might act as a sump. But I think it might be having issues with the gravity feed because of this huge filter. Pump is mounted below the tank. I bought a turbo volvo fuel pump for $80 at advanced auto with a warranty. Works good so far but I think Im going to switch my setup around some more.
Author:  tw9294 [ Sun May 09, 2010 8:09 am ]
my summit pump directions say to mount the pump HIGHER than the bottom of the tank. I use a cheap inline filter between the tank and pump because of no in tank strainer and then i have a high pressure style gm factory filter after the pump.
Author:  Stevo [ Sun May 09, 2010 11:05 am ]
I went to the salvage yard and bought three feul pumps from jaquar v12s at 25 a peice. I put a filter before and a stock subaru after. They work fine and cant beat the price.
Author:  ImmortalSoul219 [ Sun May 09, 2010 11:14 am ]
Hell yeah cant beat those prices.
Thanks for the help. I think im going to try a small filter before and than put my big one after.
Author:  perrib [ Sun May 09, 2010 2:09 pm ]
As long as you pre filter has a large inlet and outlet it should not starve. Audi used one with a 12 mm inlet and outlet. Part # 811 201 511 D. I have not tired this one but was told a WIX #33278 has 1/2" inlet and outlet.
Author:  Stevo [ Sun May 09, 2010 8:39 pm ]
True, in the jag its mounted in the trunk lower than the tank. It has 1/2 in inlet and outlet on the prefilter. Its been workin fine so far.
Author:  RaceBugg1098 [ Mon May 10, 2010 8:17 am ]
i'm running all -6 lines. My pump is higher than the bottom of the tank, cuz the tank sits on the floor. Normal running has been fine, but under 3rd gear hard turns (race conditions) it acts like im running poorly tuned carbs. I think the fuel is sloshing around or arrerating and the pump is sucking air. Im working on a "surge tank" that some road racers told me about.
Author:  ImmortalSoul219 [ Mon May 10, 2010 6:22 pm ]
Whats a surge tank? My next tank I want to add 2 baffles and a sump.
Author:  hillaholic [ Mon May 10, 2010 6:44 pm ]
http://www.google.com/imgres?imgurl=http://www.ratdat.com/images/posts08/surge_diag.jpg&imgrefurl=http://www.ratdat.com/%3Fp%3D168&usg=__My960EEfo4w_7-TC_TXtWpIUpxY=&h=296&w=440&sz=19&hl=en&start=1&um=1&itbs=1&tbnid=nW9Wwm9dpCcB1M:&tbnh=85&tbnw=127&prev=/images%3Fq%3Dsurge%2Btank%2Bfuel%26um%3D1%26hl%3Den%26sa%3DN%26rlz%3D1R2ADSA_enUS375%26tbs%3Disch:1
Author:  ImmortalSoul219 [ Mon May 10, 2010 7:00 pm ]
Thanks thats a great idea!
Author:  PhillipM [ Mon May 10, 2010 7:56 pm ]
Bosch 044, noisy, but well proven, good for 500bhp, well proven for reliability, and will happily pump petrol/2 stroke/methanol/nitro with no complaints.
Author:  Sandbar Norm [ Mon Nov 21, 2011 8:58 am ]
Well my summit pump is dieing. :cry:
It runs about 30 min. and shut off. Then 20, 10 and 5 min.
So I'm guessing as it gets warm it's shutting down. This is the one I have.
I probably have between 50 to 70 hours on it.
Anyway I didn't like how noisy it was.
Searching for fuel pumps I see these suggestion,
87 VW Vanagon
84 Toyota
Ford E2000
Delco EP286 & EP424
Bosch 44
Walbro
I'm looking for one that is not noisy and last alot longer.
Do you guys have any other suggestion of whats working for you and is it noisy?
Thanks, Norm
Author:  ridenrace6 [ Mon Nov 21, 2011 4:18 pm ]
its been a while since i used one so i dont remember how loud they are but have you tried a holley "red" (if using carbs) pump, they also have several other "inline" and "carburated" and "efi" type pumps
http://www.holley.com/division/Holley.asp#4
