It is currently Sun May 03, 2026 5:04 pm
 Post subject: Subaru on cheap side
PostPosted: Sun Jan 03, 2010 2:38 pm
I am wanting to change over from the air cooled to water cooled side and have been looking at the subaru 2.2 to keep the weight low. I am looking at buying an engine, ecu, wiring, exhaust and anything else I need from a stock car. What other parts will I need to buy, and what modifications will i need to do get it to run. I know I will need to fab motor mounts, and buy a bell housing. Anyone got any advice on the wiring harness like a diagram or is it better to buy a harness. I dont really want to spend 6k on a turn key motor.
Thanks
 Post subject: Re: Subaru on cheap side
PostPosted: Sun Jan 03, 2010 3:28 pm
http://albany.craigslist.org/cto/1509313690.html here is one
PostPosted: Sun Jan 03, 2010 4:34 pm
Out front motor sports have a ton of information. Depending how much you want to spend, they sell an aftermarket ECU that simplifies the wiring harness to just a few connectors.
They also sell every other part you might need.
Good Luck..
http://outfrontmotorsports.com
PostPosted: Sun Jan 03, 2010 5:28 pm
Put an ad on craigslist posting wanted to buy. I did that and got hits anywhere form 150 to 300 for entire car. Pull the motor and harness and scrap it.
PostPosted: Sun Jan 03, 2010 7:51 pm
Like Steve said, then order the 3x6 foot wiring diagram from kennedy engineering with the adapter, no motor mount needed the 2.2 will hang on the vw housing without any additional support.
Get a shortened oil pan while your at it.
Headers are easy with tubing bender, mine are 4 tubes into collector,comes together right behind the alternator.
Another thought, kennedy offers the flywheel as either a 200mm or 228mm, the 228mm is tempting.
PostPosted: Mon Jan 04, 2010 8:58 pm
me and bigscott are right in the middle of the same swap you can look at are posts and pics and these guys on here are great for those hard ????? im rail1914 and theres bigscott ares say suby swaps we bought two cars for 400 ea took every thing we needed and scraped the car for 100 i did my own wireing with the sheet from kennedy i think it was 40 scott sent his out and had it done for 250 .we was told 91 to 96 cars
