| PROPANE conversion...ALUMINUM TANKS http://woodsbuggy.com/phpBB3/viewtopic.php?f=17&t=8078 |
| Author: | dunebuggynut [ Sun Nov 15, 2009 4:49 pm ] |
| Post subject: | PROPANE conversion...ALUMINUM TANKS |
I worked on fork lifts for 5 years so I have some knowledge of propane systems. I plan on running a model E vaporizer (best one out there) & a VFF30 lock off unless there are better ones for off road. My question is mainly about carb size. I will be running a 2.3L Ford, 140 C.I. with forged pistons, ported head, big Esslinger cam, Offy 4 barrel intake & a header. I estimate HP around 140. Is there such a thing as too big of a LPG carb? Can I run a 425 on it since it bolts on a 4 barrel intake or is it too big? I know CFM ratings differ between LPG & gasoline but a built Pinto engine will run well with a 450 CFM carb. How well do the dual fuel converters work? I can put the ring right on top of my 465 Holley if they work well. Any help is appreciated... |
| Author: | Maddog [ Sun Nov 15, 2009 7:55 pm ] |
| Post subject: | Re: PROPANE conversion...Need advice on parts |
My crawler had a 4 barrel on 4 cylinder toyota, I changed it to a 2 barrel there was no noticable difference. I changed it thinking it would use less fuel, there was no change. Use the 4 barrel. Design your buggy for 2 tanks, so you can completely empty a tank and change over. It's a pain puttin on a new tank to be sure you won't run out, even though the old tank was half full. |
| Author: | dunebuggynut [ Thu Nov 19, 2009 6:17 pm ] |
I picked up a VFF30 lock off new in the box for $25 shipped. I have time to round up the parts so Ill wait for bargains. Youngstown Propane sells used 8 gallon forklift tanks filled for $120 ea. Anyone know of a cheaper used tank let me know. The rock crawling guys ran my specs & recommend a 200M carb on a Holley 2 barrel baseplate on my combo. Has anybody ever run the tanks vertical? They make a mount for it & I have the perfect spot for vertical tanks. Ill post updates as I round up the parts to assist others who are considering propane. |
| Author: | Maddog [ Thu Nov 19, 2009 9:31 pm ] |
I think the cheapest I've ever bought used empty tanks was for $85+ shipping so $120 filled is good. |
| Author: | dunebuggynut [ Mon Dec 14, 2009 12:32 am ] |
Anybody need tanks??? I got a hell of a deal on aluminum 8 gallon 33 pound tanks. 65 bucks each. I wanted 4 but to get that price I may end up with 8. Ill know for sure in a few days. I may have 4 to sell at that price. These are aluminum tanks....20 lbs. lighter than steel. |
| Author: | rockrockets1 [ Tue Dec 15, 2009 10:47 pm ] |
| Post subject: | Re: PROPANE conversion...ALUMINUM TANKS |
I don't remove my tank to fill it . Mr Burns showed me how to fill it with another tank .So I have a drag tank that holds 12 gal 'and I just fill the one in my buggy .Works great . And like MD said run it you may like it .I am putting dual 425 units on my little v6 |
