It is currently Sun May 03, 2026 3:41 pm
 Post subject: My Subi swap
PostPosted: Mon Jun 15, 2009 8:32 pm
Thought I would share pics of my swap. I am pulling out my 1915 and going with a 2.2 out of a 1996 Impreza. I was already running the wb tranny so I decided to go with the bell housing adapter. I know I posted pics of the bell housing already but I added them here too.
 Post subject: Re: My Subi swap
PostPosted: Mon Jun 15, 2009 9:15 pm
Nice buggy! keep us posted! Looks like you got more than one project kickin!
PostPosted: Tue Jun 16, 2009 5:01 pm
Nice project, but I really didn't notice anything but an extremely nice big garage!! :shock:
PostPosted: Tue Jun 16, 2009 5:08 pm
what for shifter setup do you run with that 091?
PostPosted: Tue Jun 16, 2009 8:47 pm
Thanks, I'm still getting it organized. I just built it and moved my shop into.
PostPosted: Tue Jun 16, 2009 9:01 pm
Turboblue sells the linkage. His shop is Davis Racing and there are links to it on this forum. I've had mine for a few years not sure if the price is still the same but he was selling them for 250.00 Here are some pics.
PostPosted: Wed Jun 17, 2009 10:09 pm
cold air is better then no air
PostPosted: Sat Jun 20, 2009 6:31 pm
I got the oil pan welded, painted and installed. I also got the cams back from Delta Cam and got the heads all back together and installed. I've read some post on what to do with the heater lines going to the heater core and I decided to weld them closed. Here are some pics.
PostPosted: Sat Jun 20, 2009 9:42 pm
My heater hoses are blocked too, but I left the little hose connected. It flows water past the thermostat for it operate properly. What year motor is that? My exhaust has two holes in the head not one.
PostPosted: Sat Jun 20, 2009 11:37 pm
The smaller hose circulates water from the IAC if equipped and the throttle body. Both should have water to keep from icing up on cold humid days.
I ran a hose from the outlet of the throttle body down to the water pump where the steel tube goes.
PostPosted: Sun Jun 21, 2009 4:21 pm
It is a 96 out of an Impreza. I blocked it off after the outlet for the hose to the throttle body.
PostPosted: Mon Jun 22, 2009 11:51 pm
First test fit of the subi engine. Does not look like I will have to modify very much.
PostPosted: Tue Jun 30, 2009 4:51 pm
all '96 and newer 2.2s have single port exhaust. kinda strange.....
awesome project, and awesome shop! color me jealous :oops:
Subaru wiring: NumbchuxConversions
PostPosted: Wed Jul 01, 2009 9:16 am
Except the VW logo on the back!
"Lets go get stupid"
PostPosted: Fri Jul 03, 2009 4:34 pm
hehe, I just noticed the impreza in the background of this pic:
looks like a '96 Lx......donor car? 8)
PostPosted: Sat Jul 04, 2009 9:04 pm
I guess I'm going to have to change that to Subaru!
That is a 94 I picked up for 300.00 for parts, but ended up selling it for 650.00! Still got my eye out for a 96 just to have extra parts.
PostPosted: Sun Jul 26, 2009 11:10 pm
I finally got to work on the buggy this weekend, I've been working out of town. Here's some pics of what I got done.
Welded up the water lines going to the throttle body
Got the motor mounts made:
Raised the gas tank
Got the engine all the way back together
PostPosted: Thu Jul 30, 2009 9:35 pm
Started on the exhaust today. I bought 3 1 5/8 j bends with a 2" radius from summit at 16.00 apiece. I cut the flanges off the stock exhaust. I ended up moving it higher and was 1 piece short to do both sides. :oops:
PostPosted: Thu Jul 30, 2009 10:46 pm
looks awesome!
a thought: you'll probably want to bring the 2 pipes together. leaving them independent really hurts the power, as these boxers really rely on the scavenging effect from one side to the other.
PostPosted: Fri Jul 31, 2009 7:59 pm
numbchux wrote:
looks awesome!
Thanks, I was planning to make a crossover pipe just to have a place to mount the o2 sensor out of the way. I didn't know that not having it would hurt the power output. Thanks for the info!
PostPosted: Fri Jul 31, 2009 8:45 pm
Cant wait to see it at Haspin. Let us know when your ready to try it out.
PostPosted: Thu Aug 13, 2009 10:16 pm
I had to modified the oil fill to clear the exhaust. I also got my radiator this week and started to mock it up.
I cut the bottom off so I could clock the fill
I then used SEM panel adhesive to glue it back together
I got the same radiator the suby steve is running.
PostPosted: Thu Aug 13, 2009 10:27 pm
Nice choice in rads! 8) Car is looking great! outfront has a short billet oil filler, I like mine. I was worried about breaking the plastic one off.
PostPosted: Thu Aug 13, 2009 11:22 pm
Thanks, I'm hoping to have it running next week. :D I did see the oil neck from outfront, but it would be right under the exhaust and i would need a funnel.
PostPosted: Fri Aug 14, 2009 8:18 am
Awesome fab work!!! Very impressive!
