1.6/1.9 Diesel adapter where can I get one???
http://woodsbuggy.com/phpBB3/viewtopic.php?f=17&t=7273
Author:  big specht [ Mon Jul 27, 2009 8:09 pm ]
Post subject:  1.6/1.9 Diesel adapter where can I get one???
Like the tital says where can i get a diesel adpater to a air cooled bug tranny???? And what clutch will I need. THANKS :D
Author:  MadMike [ Mon Jul 27, 2009 8:55 pm ]
Post subject:  Re: 1.6/1.9 Diesel adapter where can I get one???
The following is a list of adaptors that Kennedy makes for the VW.
4 CYL. ENGINES
Type 4
VW 8 dowel gland nut hole
356, 912 Porsche
Chevy II
Dodge Colt
Dodge SRT4 / Neon
Datsun, Naps Z
Ford 2.0, 2.3
Ford Escort
Chevy Vega
Volvo B18, B20, B21
Toyota T
Honda
BMW
VW Rabbit
Ford Cortina
Ford Fiesta
Chevy Citation
Ecotech
Jeep 2.5
Pontiac Iron Duke
Chrysler 2.2
Datsun A
Subaru 1.8 OHV
Saturn 1.9
Nissan SR20
GM Quad 4
Pontiac Sunbird
Toyota S
Toyota Tacoma, '96+
Subaru 1.8 OHC
Toyota 20-22R & 18R, 18RGU
Subaru 2.0, 2.2 & 2.5
Toyota A, MR2, 4AG
Acura Integra to '89 & 90+ & Del Sol
Mazda 1.8 DOHC
Honda S2000 - rotates correct direction
Honda Prelude 2.2-2.3
Mitsubishi 2.0
Toyota 1.8 1ZZ
Ford Duratech 4 cyl.
6 CYL. ENGINES
Buick V6 1962-63
Ford 4.0 SOHC
Ford 60º V6
Porsche, 6 bolt or 9 bolt
Buick V6, RWD
Chevy Corvair, reversed engine
Chevy Corvair, Std.engine
Chevy 90º V6, Pre '86
Chevy 90º V6, '86+
Chevy 4.3 V6, '96+ alum. oil pan
Ford 90º V6
Volvo V6
Chevy 60º V6
Buick 3.0 V6
GM & Buick 3.8 V6, FWD
Ford 3.0 V6
Ford 3.0, 3.2 SHO V6
Ford 3.8 V6 FWD
Mitsubishi 3.0 V6
Chrysler 3.5 300M
Nissan 3.0 V6, '96+ with sensor $200 extra
Subaru 2.7 opposed 6
VW VR6 Passat, Jetta
Acura 90 degree 2.5, 2.7 V6 & 3.2-3.5 V6
Acura 60 degree, 3.0-3.6, Acura MDX & Ridgeline
Subaru 3.3 opposed 6
Ford Probe Mazda 2.5 DOHC
Toyota 3.0 V6
Ford Contour V6
Izusu V6 3.2
Cadillac 2004 3.6 V6
V8 ENGINES
Buick 215, Aluminum
BMW V12
Chevy, Pre '86
Chevy, '86+
Chevy LS1, LS2 & all LS series engines.
Dodge Viper V-10
Ford Windsor
Ford 4.6, 5.4 , V10
Hemi 5.7 & 6.1
Nissan 5.6 V8 Titan
Northstar V8, Cadillac or Aurora
Lexus V8
Author:  dragaddict [ Tue Jul 28, 2009 4:18 am ]
Try Phil's bug shack, 606-474-2889 . In the past he has made several for me, if it is one he has never done you will have to get the motor to him and leave it, so he can get the measurement needed to make it fit.
Author:  big specht [ Tue Jul 28, 2009 8:45 am ]
I will try to call Kennedy I saw he made ones for the rabbit but it didn't say any thing about diesel stuff. THANKS
Author:  Odyknuck [ Tue Jul 28, 2009 8:49 am ]
Kennady will make any plate you want. That is how there list got as long as it is.
Author:  big specht [ Tue Jul 28, 2009 11:37 am ]
Ok I called them they have a 8'' or 9'' clutch avalable . What do you guys think ???? I'm planning building the pump and differant injectors and turbo . Or does any body know of any one that has done this swap before???? THANKS
Author:  jeepzilla [ Tue May 11, 2010 12:22 pm ]
am planning on doing something similar if not the same thing... how did this work for you? Driveable? crappy?
Author:  benscollision.com [ Sun Jun 20, 2010 1:48 pm ]
wondering how the diesel build(s) work out? aren't diesels usually heavier than the same size gas engine ..
Author:  Maddog [ Mon Jun 21, 2010 9:41 pm ]
Personally, I wouldn't consider a diesel. They just don't turn enough RPMs.
Author:  benscollision.com [ Sun Jun 27, 2010 11:22 am ]
yeh but they make twice the torque at half the rpm
Author:  kybuggy1 [ Mon Jun 28, 2010 9:00 pm ]
Yeh, but they are turds in the woods.
Author:  passat2800 [ Mon Jun 28, 2010 10:36 pm ]
I have got 3 of those diesel bell housings for $100 each that will let you use a vw product but I will club you if u buy one.Only if u already have the stuff to go with it.i have a vr6 Passat motor but the water jacket is to fat to use it as it interferes with the starter.4 cyliders work but they say u must use a diesel starter and fly wheel.You may pull a stump but what if you want to lite some tires up? Nobody has made more live and learn mistakes than I have.Do your homework.
Author:  benscollision.com [ Tue Jun 29, 2010 9:35 am ]
if something would pull a stump, it will sure as shit light a tire!
