It is currently Sun May 03, 2026 10:59 pm
 Post subject: 2.2 Performance
PostPosted: Mon Dec 22, 2008 9:46 pm
Does anybody know where to get 2.2 stuff. I found alot of 2.5 stuff but not very much for the older 2.2.
 Post subject: Re: 2.2 Performance
PostPosted: Mon Dec 22, 2008 10:20 pm
I gave up looking so I'm just adding 2 more cylinders :?
PostPosted: Mon Dec 22, 2008 10:44 pm
Are you talking Chrysler 2.2 or GM 2.2? :twisted:
PostPosted: Mon Dec 22, 2008 10:51 pm
thats mean
PostPosted: Wed Dec 24, 2008 2:07 pm
what do you need and how many??
PostPosted: Wed Dec 24, 2008 2:35 pm
I was looking for a set of cams
PostPosted: Thu Dec 25, 2008 12:51 am
Webcam sells several camshafts for subarus. You may want to check with them. Subi cam's are high $$$ stuff. I priced a set of cam's for my 98 2.5 DOHC and it was around $1000 just for cams.
John
PostPosted: Thu Dec 25, 2008 1:06 am
dave 1 steve 0
PostPosted: Thu Dec 25, 2008 9:59 am
John
I can find cams for 2.5 dohc but cant find any for 2.2 sohc. Thats the problem.
PostPosted: Fri Dec 26, 2008 10:57 pm
i cant tear em down but i do have 2 for 100 ea. then after that they will be 150-200 depending on yr and mileage
im also interestd in trading for vw motor parts or buggy related thanks brad
PostPosted: Mon Jan 05, 2009 4:49 am
DELTA regrinds. http://deltacam.com/
throttle body spacer (I'm running a Group A one in my wagon. took a little (very easy...) modification to mate to the OBD I throttle body.
equal length exhaust header
Grimmspeed phenolic intake manifold spacers (tell him I sent you....probably won't get a discount, but then I can bitch at him for not sending business my way like he promised :evil: )
that's about all there is for an N/A engine. but that will give it quite a bit more grunt.
Subaru wiring: NumbchuxConversions
PostPosted: Mon Jan 05, 2009 8:16 pm
Thank you, they said I will have them back within a week depending on ups!
PostPosted: Tue Jan 06, 2009 4:32 am
yep, great guys out at Delta. and they know their stuff. they've been doing this for a long time. even have stuff for '80s subaru engines too!!
PostPosted: Tue Jan 06, 2009 9:18 am
If you regrind the cam for more duration or whatever,,will the computer accept it? I assume it will since it don't seem to be an issue.. and then how do you decide what grind to use,,mimmick a hot cam used in the AC world? Or has the hot Suby's already figured it out? :?
PostPosted: Sun Mar 29, 2009 6:30 pm
Yesterday I got the new camed motor fired up. It has a lope at idle and the throttle responce is instant. I had to put a new motor together since I lost a valve guide a couple of weekends ago. This one only has 184000 on it instead of 216000. I cant wait to get out in the woods and see how it runs. I will say Delta cams has it down pat. Sounds strong running it around the parking lot. Smokes the tires right off (might need to invest in 930 now).
PostPosted: Sun Mar 29, 2009 8:10 pm
Wicked,,,just might be the ticket,, be sure to bring it to Curt's Easter Hill Climb 8)
PostPosted: Sun Mar 29, 2009 8:41 pm
Sorry but im not going to make that ride. I have spent way to much latly. I will make wellsville thats for sure.
I spent a little too much for a new camper.
PostPosted: Sun Mar 29, 2009 9:32 pm
Wow I realy like the new set up
PostPosted: Mon Mar 30, 2009 10:10 am
very nice steve...can you get 2 stacked in there?
"Lets go get stupid"
PostPosted: Fri Apr 03, 2009 10:27 pm
I know where im sleeping this summer!!!! hehehehehe does it have a potty?? haaaaaaaaaaaaaaaaa i love you.
