lot of question
http://woodsbuggy.com/phpBB3/viewtopic.php?f=17&t=5445
Author:  Andrew_Ha [ Mon Dec 29, 2008 7:38 pm ]
Post subject:  lot of question
ok the first question is where do i start with the questions. (lol) i want to start a new buggy build this spring, i want it to be w/c. the problem is i've never seen 1 up close to see how they are plumbed, wired and so on. doing elctrical is not a real problem for me. im not a strong weilder, or fab. these are just things i've never done alot of. so i guess the first real question is this a project i should take on. or should i just stay a/c where i a least have a little knowledge. cause i have no idea wherei would have to start on a w/c
Author:  Stevo [ Mon Dec 29, 2008 7:46 pm ]
Post subject:  Re: lot of question
I live 40 mins from wellsville, your more than welcome to come up and look at it. Its not as hard as it looks. Madmike helped with mine and made it look easy.
Author:  Andrew_Ha [ Mon Dec 29, 2008 7:50 pm ]
i might take you up on that month when i get home from work. i get off the boat the 13
Author:  nickschlemer [ Mon Dec 29, 2008 8:16 pm ]
Go for cant learn if you dont try.. Thats how i learned i didnt even know how to weld tell after i bought a buggy and welder..
Author:  Andrew_Ha [ Tue Dec 30, 2008 8:28 am ]
also do i need to go with air bags due to extra weight or would a good set of coil overs due the trick. i'm going with custom torsion
Author:  Firebug [ Tue Dec 30, 2008 9:20 am ]
Coil overs are excellent springs,,,just takes more trial and error to set up..unless you are real smart and real lucky.. ( and richer ) Air bags are more user friendly,,just my humble opinion :?
Author:  harleyhunter05 [ Tue Dec 30, 2008 8:25 pm ]
bags are cheaper and easy to set up -- i wouldnt change mine for nothing
Author:  Andrew_Ha [ Tue Dec 30, 2008 8:29 pm ]
thanks for all the answers. but it don't mater now all projects on hold just got layed off
Author:  kendel [ Tue Dec 30, 2008 8:36 pm ]
I might get layed off tto. The question is should I go ahead and buy stuff for projects so when i have time I am set, or should I save my money just in case I might?
Author:  Andrew_Ha [ Tue Dec 30, 2008 9:03 pm ]
that's a good question iwas planning on using taxes to buy new stuff but know i'm going have to bank it and hope it is enough to get me through. god willing i can find some work esle where. i prey it don't happen to u. i have a little money put back but i still know its never racking just worring about how your going to get through it
Author:  nickschlemer [ Tue Dec 30, 2008 9:44 pm ]
Yeah they said if we make it through march we wont have to worry about lay offs, but everythings in the air right now. What did you do Andrew..
Author:  Andrew_Ha [ Tue Dec 30, 2008 10:08 pm ]
i'm a tow boat captian. should be able to find work just have to take a pay cut
Author:  kendel [ Tue Dec 30, 2008 10:12 pm ]
If you can drive a boat you could run a train?
Author:  Stevo [ Tue Dec 30, 2008 10:15 pm ]
now that you have time, come check out the suby. I'm sure we could go down and look at madmikes too.
Author:  Andrew_Ha [ Tue Dec 30, 2008 10:20 pm ]
pm your phone number
Author:  Andrew_Ha [ Tue Dec 30, 2008 10:23 pm ]
i have no idea about trains what's it pay might think about it
Author:  Andrew_Ha [ Thu Jan 01, 2009 11:53 pm ]
steve i found another boat to get on so i'll get ahold of u when i get home this time
Author:  DVS1 [ Fri Jan 02, 2009 12:09 am ]
2 different crafts. I'm a locomotive engineer and I have to pass hazmat, air brake, train handleing, Federal Railroad Association rules, ect. ect. Harley, rumor has it that Norfolk Southern is hireing again, check their website out.
Author:  MadMike [ Fri Jan 02, 2009 7:56 am ]
Any time you want stop by.
