GM question
http://woodsbuggy.com/phpBB3/viewtopic.php?f=17&t=4105
Author:  TrackerCasey [ Wed Jun 25, 2008 9:11 pm ]
Post subject:  GM question
While I was Putting coolant in my buggy for the first time today.(It has a 4.3 v6 with a Moroso electric water pump) it started pouring coolant out of the un-used hole on the left side of the block.. my question is why and what do I do to remedy this the right way?
And buying a Ford/Dodge is NOT the answer I'm looking for!!! :lol:
Author:  Stevo [ Wed Jun 25, 2008 10:39 pm ]
Post subject:  Re: GM question
That is a bypass port. Tap it for a pipe plug and plug it off. Thats what I did on my v-8 fiero. It is not needed with electric pumps.
Author:  TrackerCasey [ Thu Jun 26, 2008 1:04 pm ]
Thanks !!! Don't suppose you know the size of tap off hand do you?
Author:  instigator [ Sun Jun 29, 2008 8:51 pm ]
go to the auto parts store and by some small freeze plugs that will do the trick.
Author:  Stevo [ Sun Jun 29, 2008 9:01 pm ]
I used a small 1/8 npt inch pipe plug worked great with teflon tape.
Author:  Griffin [ Sun Jul 06, 2008 6:33 pm ]
Make sure you use GM gaskets for the waterpump. The felpro and other aftermarket gaskets I've had blow out. This happened to me twice. And yes, I was tightening it correctly. The torque spec is 33 ft lbs for the water pump bolts.
John
