 Post subject: plastic plug housings
PostPosted: Sun Jun 15, 2008 10:26 am
pulled the Honda motor a few weeks ago to fix my trans, first time I have put a wrench to it since it was installed over a year and a half ago :wink:
it was easiest to unplug everything from the motor to pull it, what I found was all the plastic plugs were sealed good at the connections but were hard to pull apart because of mud/sand in the housings. I don't know how many plugs there are on other w/c motors but there are 20+ on mine.
I plan in using die-electric grease on all the housings when I re-install the motor, should take care of the problem......
Ran for a year and a half with a stock 6 rib......now I'm gonna have weddle first, second and a super diff 8)
Mike
Got Honda?
PostPosted: Sun Jun 15, 2008 10:51 am
You are going to be a top contender for sure now.
PostPosted: Tue Jun 17, 2008 7:24 am
Lookin forward to seeing it go! You gonna be at drag race?
Larry
PostPosted: Thu Jun 19, 2008 11:41 pm
[quote="kybuggy1"]Lookin forward to seeing it go! You gonna be at drag race?
Larry[/quote
going to drop in the motor tomorrow night, I may go, what time does it start?
Mike
Got Honda?
PostPosted: Fri Jun 20, 2008 9:07 am
I think the practice time runs start at noon.
Me and Clayton probably get over there by 10:30 or so.
Larry
PostPosted: Fri Aug 01, 2008 7:19 pm
Jelly powder,,your a top contender for sure. I use that grease stuff your talking about and it comes in a little can you can pull a trigger and it comes out of a straw thingy. It is a very good vapor barrier too. Everyone should use it on their spark plugs too. I hope you bring the Honda machine down to bama for the hill climb. 8)
