 Post subject: Radiator Fitting?
PostPosted: Sun Jun 01, 2008 8:11 pm
What's this fitting for?
Bryan
 Post subject: Re: Radiator Fitting?
PostPosted: Sun Jun 01, 2008 8:37 pm
Hard to tell but it may be for the automatic transmission cooler,,or something :?
PostPosted: Sun Jun 01, 2008 8:49 pm
Thats for transmission cooler. I have the same rad in the garage. There should be another one down lower. Is it leaking?
PostPosted: Sun Jun 01, 2008 9:10 pm
I haven't filled the rad up yet. It's loose and just has a rubber cap on the end so I didn't know if I need to tighten it or plug it.
Bryan
PostPosted: Sun Jun 01, 2008 9:33 pm
as long as the nuts are tight in the tank, you dont have to do anything. Somtimes the fitings come loose and leak water from the fiting. I would plug them incase you need a cooler and keep dirt out.
PostPosted: Sun Jun 01, 2008 9:36 pm
Thanks!
Bryan
PostPosted: Fri Nov 28, 2008 4:57 am
If that is the tranny cooler connection, why couldnt one run the engine oil thru it? Or would it get too warm running it through the radiator?
PostPosted: Fri Nov 28, 2008 9:05 am
Passages in tranny coolers usually too small to run oil thru. They wont flow enough volume thru them. Found that out the hard way a few years ago. :roll: .
Larry
PostPosted: Fri Nov 28, 2008 11:17 am
Ok, not enough flow. Makes sense. Thats why I asked.
