 Post subject: plumbing for radiator
PostPosted: Tue May 13, 2008 12:14 pm
i was wondering what would be a good thing to run from the engine to the radiator for coolant to flow through that wont rust or explode over a long distance?
when in doubt gas it
PostPosted: Tue May 13, 2008 1:15 pm
These would work great and look good too. This is what Plumberbill used on his Subi motor.
http://store.summitracing.com/partdetai ... toview=sku
PostPosted: Tue May 13, 2008 1:42 pm
When I did my suby nearly 4 yrs. ago,I bent frame tubing that would reach from motor to radiator and welded it to frame, then used hoses to connect up.
Never had a problem in 4 years.
Bill
PostPosted: Tue May 13, 2008 2:30 pm
Bill
i know this works perfectly. most of the rockcrawlers with rear mounted radiators just tap into the frame tubing. they just have an inlet up my the motor then an exit at the rear for the rad.
"Lets go get stupid"
PostPosted: Tue May 13, 2008 9:41 pm
Most all anti-freeze has rust inhibitors in them. As long as you change it every couple of years there shouldn't be any problems.
PostPosted: Tue May 13, 2008 10:27 pm
that is what i am asking the question for is a rock crawler,no one would know how to run this stuff and have it hold but better than buggy guys i think.the radiator is gonna be mounted in the rear so any help on mounts or anything guys wouls be appreciated
PostPosted: Wed May 14, 2008 12:14 am
My KEP adapter manual says you can use electrical conduit, so that's what I planned on using. Anyone have any objections to using something like that?
Get me that hammer, pronto!
PostPosted: Wed May 14, 2008 1:44 am
Flex-kool or Flex-cool hosing get it on ebay for the best prices. I just got another 48" piece for 50$ i have a 24" piece i dont need id probably let go for cheap..
PostPosted: Wed May 14, 2008 7:37 am
that sounds like a great idea, it's galvanized, you could get a piece bent to your needs for a few bucks from an electrical contractor, supply house, etc.........
Mike
Got Honda?
PostPosted: Fri May 16, 2008 10:56 pm
i used some type of aluminum exhaust tubing.the muffler shop bent around the motor,then tied it in with short hose and double clamped.it is lite,simple,and cheap.
