It is currently Sun May 03, 2026 7:00 pm
 Post subject: Suby Oil Leak,,,HELP
PostPosted: Fri Feb 29, 2008 5:45 pm
My engine has developed a leak . After sitting for about a month I fired it up and it is leaking oil pretty bad from behind the cam belt cover... Some of you Subaru Guru's got any idea what I'm getting into? Isn't the oil pump back there? I will pull the cover off soon and investigate. :cry:
PostPosted: Fri Feb 29, 2008 11:59 pm
I'm not sure but does the oil go up thru the headgaskets?
PostPosted: Sat Mar 01, 2008 12:12 am
the oil is coming from the timing belt area.Im gonna change the belt and I think the oil pump is belt in there too. :oops:
PostPosted: Sat Mar 01, 2008 12:34 am
could be a couple things that could leak inside the covers. cam seals, crank seal, oil pump and cover. only takes a minute to remove the timing belt housing for inspection
- Sigmund Freud
- Antonio Meloni
PostPosted: Sat Mar 01, 2008 1:03 am
[quote='plumberbill']could be a couple things that could leak inside the covers. cam seals, crank seal, oil pump and cover. only takes a minute to remove the timing belt housing for inspection[/quote]
Right on target Bill. Since your going to open up the covers might as well change water pump and oil pump along with the belt. Cheap insurance. You'll probably have a harder time removing the covers than doing anything else.
PostPosted: Sat Mar 01, 2008 2:54 am
thanks guys, I have changed the end covers and the bolts are a b!tc# because of corrosion. Gotta pull a shift tomorrow but maybe after church Sunday. :wink:
PostPosted: Sat Mar 01, 2008 12:11 pm
[quote='Firebug']thanks guys, I have changed the end covers and the bolts are a b!tc# because of corrosion. Gotta pull a shift tomorrow but maybe after church Sunday. :wink:[/quote]
i have just one word for you.........antiseize
- Sigmund Freud
- Antonio Meloni
 Post subject: Re: Suby Oil Leak,,,HELP
PostPosted: Sun Mar 02, 2008 10:20 am
[quote='Firebug']My engine has developed a leak . :cry:[/quote]
Get a AC. :eek: :o
PostPosted: Sun Mar 02, 2008 10:25 am
The only thing an AC engine doesn't leak is coolant. I'm fixing the oil leak. I'm changing the whole oil pump seal , O-ring and all . :roll:
PostPosted: Sun Mar 02, 2008 12:26 pm
I have 2 AC's that have never leaked :!:
PostPosted: Sun Mar 02, 2008 1:35 pm
I got some ocean front property in Tn for yu 2. :roll:
PostPosted: Sun Mar 02, 2008 1:37 pm
[quote='Firebug']I got some ocean front property in Tn for yu 2. :roll:[/quote]
sold :o
PostPosted: Sun Mar 02, 2008 2:06 pm
I had 2 AC's that did leak and one WC that does too!!! Maybe I need better gaskets. :eek:
